Page 1 of 2 12 LastLast
Results 1 to 10 of 19
    Aug 2016
    115
    Tire shine driveway stains
    I’ve been using megs hyper dressing for over a year now. Not sure the dilution. I take a 16oz fill it up with water and add maybe 2-5oz.
    I spray on the tires and let it sit usually I will spray tires then go dry door jambs come back to rub in the dressing.
    This month 3-4 people have told me no more tire shine as its leaving stains in the driveway. Each part of the ground will have a little circle where it’s not discolored from water. Mostly these people are finding when it rains you can see where the car was parked.
    Im going to apply differently, just rub it in immediately. Any other tips?
    Aug 2010
    New Jersey
    15,196
    Re: Tire shine driveway stains
    Are you sure it's not the spraying that's the problem, rather than the "letting it sit" vs. "rubbing it in immediately"? I've never had this problem except when using aerosol dressings; maybe you should just use an applicator rather than spraying? The other thing to do would be to put a towel on the ground or cut out some pieces of cardboard to put down to mask the driveway.
    Aug 2016
    115
    I’m not sure it’s anything. I do know it creates like a crescent moon under the tires so I assume it’s the stuff running down.
    Idk when I would rub it in immediately I feel like when it dries it’s patchy, when I leave it sit it absorbs nice into the pourous rubber.
    Aug 2010
    New Jersey
    15,196
    Crescent moon sounds like overspray--try using a tire swipe or other applicator to apply instead of spraying, and see if that helps.
    Dec 2006
    798
    Exactly. Use a tire swipe or and old sponge to apply. You'll save a ton of product too.
    Nov 2015
    Los Angeles, California
    13,778
    Quote Originally Posted by RiverCityAutoSpa View Post
    Spray Hyper Dressing into a flag tipped brush then brush it into the tire. I guarantee It’ll solve your problem + no overspray.
  7. Likes gspam1 liked this post
  8. #7
    Jun 2013
    Montreal, Quebec
    3,996
    It's making the surface of the concrete hydrophobic. So it's not really a stain but what ever LOL.
    Like others have said, just spray into your applicator and apply, you won't get dripping that way. I love Adam's applicator. Tried several applicators over the years and that one is the closest to perfection I have found. It is the right size and grip and it applies products very well. Regardless of what applicator you use, 4 or 5 sprays into the applicator is usually enough to do a tire. After it has soaked in for a few minutes, you can buff with a microfiber towel to make it look perfect.
  9. #8
    Super Member Route246's Avatar
    Mar 2017
    NorCal - San Mateo County
    1,037
    Very nice idea! I'm going to try that. I have those curved spongy applicators but they are a pain to use. The brush looks like a winner.
  10. Likes Eldorado2k liked this post
  11. #9
    Super Member Bill D's Avatar
    Mar 2006
    The First Coast of FL
    2,381
    I gotta see if my brush that looks similar to the one in the photo will work. Otherwise I suppose that exact one is available from Autogeek.
  12. #10
    Super Member Finick's Avatar
    Jul 2017
    885
    Quote Originally Posted by Bill D View Post
    It’s for sure worth getting one to apply dressing.
    I kept seeing eldorado2k posting about doing it that way for awhile before I ordered a new brush and used my old one for applying tire dressing.
    Applying tire dressing after every wash irritates me, but using that brush to apply it is probably the easiest/fastest way I’ve ever experienced.
    10/10 highly recommend.
  13. Thanks Eldorado2k thanked for this post
  1. Will Tuf Shine Tire Cleaner Stain Driveway Pavers?
    By Chevota Guy in forum Auto Detailing 101
    Last Post: 05-29-2019, 10:24 PM
  2. any way to avoid brake dust stains on driveway
    By lj993 in forum Tricks, Tips and Techniques
    Last Post: 03-01-2018, 08:26 PM
  3. Help out a Newb - driveway spots caused by tire / wheel cleaning products
    By dirtyboysdetailing in forum How to make money detailing cars
    Last Post: 05-01-2017, 10:20 PM
  4. Tire Shine Driveway
    By BlackRam in forum Auto Detailing 101
    Last Post: 01-11-2014, 05:31 PM
  5. How to remove tire dressing marks from driveway
    By superd in forum How to Articles
    Last Post: 03-22-2012, 07:54 PM
