Re: Very surprised by the lack of filler removal by gyeon prep
Originally Posted by Loach
I’d say the main problem for me is I’m addicted to how good Eraser smells.
It does smell good. One car I did last summer, the guy was, "Man, what IS that stuff?! Smells so good!" He kept picking up the bottle and reading it over.
What we're you working on?
What type of tool did you use?
What was the sanding paper or disc?
Originally Posted by WRAPT C5Z06
My test hood. Black OEM Volvo paint.
Rupes 15mm II
Rupes 3000 foam backed disc(sanded with 12mm DA).
So the reason I asked is because I've done a fair bit of sanding in my life and one thing I've learned by experience is the most effective way to 100% remove sanding marks is to go full pedal to the metal and use a wool pad with a rotary buffer. Not only is it more effective it's usually faster. Then I remove my holograms.
What I have experienced when using foam pads on any orbital is the sanding marks are not removed - this is what you experienced. My guess is, if you had used a wool pad on a rotary buffer with a compound, there would not have been any sanding marks to fill thus one and done.
I purposely tried not to eliminate all sanding marks. I was testing the cutting ability between two compounds. I went with a foam pad, as I knew there would be scratches left over, but I wanted to see which compound removed more. Regardless, the fact gyeon prep only removed the topical oils surprised me, as it didn't reveal anywhere near the true finish. I felt like I did a magic trick when I wiped with Gtech panel wipe...lol.
Sent from my ONEPLUS A6013 using Autogeekonline mobile app
That makes sense.
Sent from my SM-N920T using Tapatalk
Someone should do a detailed side by side comparison between several of these products on the same panel to see which ones perform the best. And don’t forget the pics.
same here,,for cutting out wetsanding wool is the way to go,,I follow up up with either a foam pad on the rotary or grab the orbital,,,,or both,,depnds on the color and how much area I am working with.
I have found that the LC orange pads on the orbital,on speed 6 will work good on small areas (about dollar bill sized) although now I am using Carbrite Select orange pads and getting the same results.
The company my supply guy works for no longer does business with LC (for now anyway) but the CB select pads are pretty durable as well.
“I have trouble with names and faces, but I never forget a car.”
Meguiars microfiber pads w/D300 can do it on speed 4 using an 8mm MT300. That’s how my car was done and it left it lsp ready to boot.
Post Thanks / Like - 0 Thanks, 7 Likes, 0 Dislikes
Came across Kleanstrip Prep-All paint prep locally. Really like this stuff. Slick wipe off and really digs deep to remove those fillers. Way better than IPA based prep sprays, IMO.
Originally Posted by Eldorado2k
I'm surprised the D300 w microfiber isn't mentioned more often. It's a great combo that cuts deep and leaves a respectable finish. Definately a 'low and slow' proposition to really make it effective but the stuff just plain works.
Seriously. You saw what it did for my other Caddy too. There’s a reason why it was the 1st thing I reached for and it didn’t disappoint.
By heloguy in forum Auto Detailing 101
Last Post: 05-25-2022, 12:08 AM
By Wolfslair in forum Auto Detailing 101
Last Post: 09-05-2016, 04:53 PM
By Cleanex in forum Ask your detailing questions!
Last Post: 04-12-2015, 04:55 PM
By KoshiL in forum Show N' Shine
Last Post: 04-28-2014, 04:10 PM
By iron_worker in forum Show N' Shine
Last Post: 10-29-2013, 09:10 AM
Members who have read this thread: 22
- msharpe785,
- ollever,
- Silly Rabbit,
- vobro,
- TroyScherer,
- Karl_in_Chicago,
- Danube,
- Setec Astronomy,
- Loach,
- SNP209,
- Odrapnew,
- CleanIT,
- Kneel,
- DUBL0WS6,
- Optimus Grime,
- BTW574,
- DFB,
- Desertnate,
- John U,
- ps2cho,
- ellens2,
- MTCarNut
26 | 27 | 28 | 29 | 30 | 31 |
