Page 1 of 3 123 LastLast
Results 1 to 10 of 24
    Jul 2016
    3,328
    A question of claying and working backwards?
    Any of these synthetic clay mitts, towels, real clay bars ect marr the living heck out of your paint. Is this really worth doing when your car is in great shape. All it does is make your paint worse. Is this not working backwards?
    I know it's very superficial and comes out easy but still. I've use the finest bars and sponges. They still cause a great deal of marring. Especially if u do it quick after the decon wash.
    If your car is properly maintained is it really picking up enough contamination to justify doing this? Now you're polishing step is going to get you back to where you were instead of somewhere more refined.
    Thoughts?
  2. Likes Brandon Wetch liked this post
  3. #2
    Aug 2010
    New Jersey
    15,171
    Re: A question of claying and working backwards?
    I find when I maintain my cars well, I get almost nothing off when I clay...so little that I wonder why I am bothering to do it. Now, last couple of years I've been pretty lax...I wouldn't be surprised if my clay results are different now...but I probably won't know that until spring.
  4. #3
    May 2014
    449
    Just depends on your vehicle and driving conditions. I sometimes find the lower rocker and fender well areas requiring a bit of claying or tar removal from time to time, the rest of my vehicle not so much.
  5. #4
    Nov 2015
    Los Angeles, California
    13,765
    Quote Originally Posted by MikeC78 View Post
    Call me crazy, but I find that all vehicles have the least amount of contaminants below the belt line and absolutely no contaminants ever on the wheels.
    Just a couple of days ago, I was doing a waterless wash for a friend of mine in order for him to slap a car cover on the car before it rained. The paint was heavily contaminated on the horizontal panels from sitting outside [its in the process of being restored and is prepped for paintjob]
    Vertical panels you can feel a bit less contamination... But the moment you run your hand below the body line on the side of the car it’s absolutely smooth. This was a clear indication that contaminants mainly affected the top sides of vehicles, hence the term “fallout”.
    I’ll stick to my guns. Lower portions of vehicles always have the least amount of contaminants and wheels have absolutely none. I challenge anyone to clay the face of their wheels after using a wheel cleaner and show contaminants on the claybar.
  6. #5
    May 2014
    449
    If you ever drive in places that use rock chip and tar, you'll see it much differently. I'm not saying my particular situation is the same as yours, and its mostly certainly dependent on many factor including your geographic location.
  7. #6
    Nov 2015
    13,765
    I will find tar down there. But as far as baggie test failing grit, it’s always noticeably less IME.
  8. #7
    Nov 2017
    245
    In my experience the most contaminated areas of most cars are a feet long area right behind the wheel wells/fenders under the belt line, the hood and the top/roof of the car. Horizontal surfaces generally get more contaminated than vertical ones (and that's because most of the surface below the belt line is usually not that much contaminated), because solved or floating particles settle easier on them, and also because any and all protection (and also the clear coat) gets degraded faster on horizontal surfaces. The reason for the latter being is that rain drops and the incident rays of the sunlight reach them in a sharper angle and in a larger amount, than the vertical surfaces.
    Wheels do not get really contaminated, because their surfaces are vertically aligned, the fender and the tire (which extends over the actual rim) prevents most - if not all - of the stuff hitting them head-on. And also because they're essentially constantly spinning, which in turn means that anything that gets them on will most likely get slung off immediately or shortly by the centrifugal and centripetal forces (with the only exception being probably the surface of the wheel cap).
  9. Likes MikeC78 liked this post
  10. #8
    Mar 2017
    Southeastern PA
    2,480
    My NanoSkin used to marr a lot too but once I stopped using ONR as lube and started using Glide things got so much better. I should have followed manufacture’s recommendation and would have had a better time with it from the beginning.
    Bruno Soares
  11. Likes mbkite, JustJesus liked this post
  12. #9
    Super Member Rsurfer's Avatar
    Jan 2007
    14,097
    Quote Originally Posted by itsgn View Post
    Tell that to Mercedes and BMW owners.
  13. #10
    Super Member PaulMys's Avatar
    Jan 2014
    Eastern L.I. NY
    10,773
    You ever drive a Caddy through a snow bank (end of the driveway), and then onto dirty salted roads?
    I'm telling you, Eldo.... That crap does some serious clinging to the lower parts and wheels. It sucks.
    Let's switch locations for the winter, Ric. It's was a balmy 17 degrees here this morning. LOL
    That said, in warmer temps, I can totally see your point about horizontal vs. vertical. Just makes sense.
  1. Going backwards to go forwards!!!
    By Aaryn NZ in forum Auto Detailing 101
    Last Post: 08-02-2018, 03:12 PM
  2. Question about claying
    By mfrickman in forum Auto Detailing 101
    Last Post: 05-29-2013, 05:34 AM
  3. Claying question
    By Hades02 in forum Auto Detailing 101
    Last Post: 04-08-2013, 07:20 AM
  4. KB Method...Priming the pad....Seems a little backwards to me?
    By Rez90 in forum Ask your detailing questions!
    Last Post: 03-23-2011, 10:36 AM
  5. Claying Question
    By muddy in forum Auto Detailing 101
    Last Post: 08-21-2008, 05:53 PM
