Page 3 of 17 FirstFirst 12345678910111213 ... LastLast
Results 21 to 30 of 163
  1. #21
    Super Member JustJesus's Avatar
    Oct 2014
    Orange & LA Counties
    1,294
    Re: SEMA 2018... 2019 Products
    How do you know? I'm sure I already know the answer
    Quote Originally Posted by Joe@Superior Shine View Post
    Meguiars 210 and 110 ROCK!! Ask me how I know!
    Sent from my SM-N920T using Tapatalk
  2. #22
    Nov 2009
    Pasadena, CA
    12,615
    There is no doubt 110/210 will be much more user friendly. Meg's wouldn't screw this up. Very excited about these.
    '03 Corvette Z06
  3. Likes dlc95 liked this post
  4. #23
    Aug 2010
    New Jersey
    15,188
    Just gathering the data from facebook, instagram to have all in one place. I am not at the show. Nothing from Optimum yet. As soon as they share something I will post it.
    I'm not sure if OPT is actually coming out with anything, other than that Gelcoat Restorer that is already on sale. There seems to be some murmuring about a tire coating but who knows when and it could be part of the Opti-Coat system and therefore pro-only.
  5. #24
    Aug 2010
    New Jersey
    15,188
    Griot's mentioned some of their new stuff about half way through this video.
    I can't believe they haven't solved that bottle problem with the foaming Surface Prep.
    I does kind of make you wonder if you should be looking at an SDS before using that...when they can't get a bottle to stand up to the formula. I'm going to have to look at that.
  6. #25
    Super Member BudgetPlan1's Avatar
    Dec 2015
    Central OH
    2,000
    Detailed Image video with Gyeon's products. A bit noisy but can be heard ok.
    A new tire gel that is water based.
    PPF specific polishes.
    Detail Spray
    Tire Cleaner
    Foam pads
    The pro line is getting CanCoat Pro which has increased Silica. Consumer gets no change.
    Second half has good info on how to chemically decon their coatings.
    Corey demoing the new CarPro Elixir and showing the new branding of the products.
    The PPF Renew sounds interesting.
    CanCoat Pro? Looking forward to the explanation behind that one.
    The 'Elixir' becoming an actual product is just plain cool.
  7. Likes SWETM liked this post
  8. #26
    Sep 2014
    524
    Thanks for doing this Guz!
  9. Likes The Guz liked this post
  10. #27
    Feb 2014
    Rochester MA
    2,627
    Looking forward to more information once the udos is released. I may have to grab some of the new M110 seeing as I like m100.
    IGL Authorized Coating/Kenzo Installer
    Final Inspection Auto Detailing- https://www.facebook.com/FinalInspection
  11. #28
    Super Member Mgavin1985's Avatar
    Nov 2017
    497
    What did you squirt menzerna or sonax into 105 and then mix it up and use it? Bet this will be awesome product I still use 105 for headlights I still use 205 as final polish always thought it was good finish.
    Any rumors on meguiars coating in development or a coating from 3D
  12. Likes dlc95 liked this post
  13. #29
    Super Member ScottH's Avatar
    Nov 2015
    Northern NJ
    895
    Re: Sema 2018
    Meguiar's brought out some new stuff like always
    These are just the one's that caught my eye. I am not going to post every product they announced.
    Meguiar's Professional Wheel & Paint IRON DECON
    This pro-strength unique gel formula will safely & effectively remove embedded iron particles from body panels, wheels and painted brake components. D1801 is also highly effective at removing road grease, grime and dirt from wheels & brakes.
    • Rapid color-changing iron remover for wheels & paint
    • pH balanced, safe on all wheels & painted brake components
    • Clings to wheels to remove road grime, grease & iron
    • Viscosity tuned for effective distribution over entire vehicle panels, while also clinging to wheels for deep cleaning
    • Special cleaning package often delivers true touch-less wheel cleaning with pressure rinsing
    • Be warned - this was built to CLEAN and REMOVE IRON, and come loaded with iron-killing stink!
    Product Number: D180101 / 1 Gallon, D180105 / 5 Gallon
    MSRP: $79.99 / 1 Gallon, $319.99 / 5 Gallon
    Size: D180101 / 1 Gallon, D180105 / 5 Gallon
    Meguiar's M110 Professional Ultra Pro Speed Compound
    • The next evolution of heavy-cutting high-gloss compounds
    • All-new compound from the ground up, featuring special SMAT abrasives that redefine what a compound can do
    • Quickly removes 1,200 grit or finer sanding marks, leaving a high gloss finish
    • Works faster and with less mess thanks to quick cutting, long buffing cycle, low dust formula
    • Designed with both standard & long throw D/A's in mind (not just rotary)
    • Easy wipe-off, virtually zero dust or sling with Rotary or D/A
    • Show Car Results when paired with M210 Ultra Pro Finishing Polish
    Product Number: M11032, 32oz / M11001, 1 Gallon
    MSRP: $47.99 US 32oz, $149.99, 1 Gallon
    Meguiar's Professional M210 Ultra Pro Finishing Polish
    Engineered to deliver flawless results on even the most sensitive paints in less time. Our best finishing, highest gloss polish - ever!
    • Creates deep, glossy finish even on dark & sensitive paints
    • All-new polish from the ground up, featuring special SMAT abrasives engineered to deliver a flawless finish
    • Excellent refining ability on even the most finicky hard or soft sensitive paints
    • Finishes down without haze, swirls or holograms
    • Follow M110 Ultra Pro Speed Compound for Optimal Results
    Product Number: M21032, 32 oz. / M21001, 1 Gallon
    MSRP: $43.99 US, 32oz / $131.99 US, 1 Gallon
    Meguiar's Hybrid Ceramic Wax
    Wax by Just Spraying on , Then Rinsing Off? YES! IT'S THAT EASY!
    No rubbing. No curing. No buffing. No mess!
    Conventional? No. Sensational? YES
    Sophisticated, hybrid ceramic chemistry uses a thick, high-viscosity formula & the power of your rinse water to help coat your car's exterior surfaces. You can actually see the extreme water beads form as your rinse! Then, simply dry as normal & your surfaces now have enhanced, hybrid Si02 ceramic protection that beads.. & beads... & BEADS water like crazy!
    Product Number: G190526
    MSRP: $14.99 US
    Size: 26 oz trigger spray
    Meguiar's 3 in 1 Wax
    Looking to restore your vehicle's paint to its former glory but don't have all day to compound, polish, and wax? Meguiar's decades of experience in paint care and surface chemistry has lead us to a breakthrough solution. Our 3-in-1 Wax will improve your paint's finish, enhance shine, and leave behind a durable coat of wax. All in one quick and easy formula!
    • Removes swirls, water spots, and blemishes
    • Increases depth of gloss and color clarity
    • Provides long-lasting protection
    Product Number: G191016
    MSRP: $18.99 US
    Contents: 16 oz liquid wax, foam applicator pad
    Some of the new Meguire's products look interesting and competitively priced (e.g. Their spray on ceramic wax)
    ScottH
  14. Likes minerigger liked this post
  15. #30
    Regular Member RaydiantDetail's Avatar
    Mar 2016
    Atlanta
    123
    Ohhhh thanks for the consolidation thread!
    Looking forward to some of the new stuff Meguiars is dropping. Iron remover, ceramic wax and the new 110/210 compound and polish.
    I wonder where the current leather cleaner of gyeon falls in with the new mild and strong. It's my go to leather cleaner currently - think it may be a middle of the way.
    Edit: apparently I dont read so well. Lol
    - Q²M LeatherCleaner Strong is the evolution of our current cleaner and features great cleaning abilities and safety on all types of upholstery
    Sent from my SM-G965U using Tapatalk
    Raydiant Reflections Auto Detailing
    Website
    Facebook
  16. Likes The Guz liked this post
  1. SEMA 2019 New Products - New Products Coming Soon!
    By VISITOR in forum New Car Care Products
    Last Post: 01-05-2020, 09:33 AM
  2. 2019 SEMA Check-in - Who’s going?
    Last Post: 10-29-2019, 07:36 AM
  3. SEMA 2018 - Mike Phillips SEMA Pictures and Updates
    Last Post: 11-05-2018, 04:06 PM
  4. SEMA 2018 New Products - New Products Coming Soon!
    Last Post: 10-22-2018, 12:45 PM
  5. SEMA 2017 New 2018 Products
    By VISITOR in forum Auto Detailing 101
    Last Post: 02-10-2018, 12:12 AM
