Re: Newby here...advice on which Menzerna polish and pads
106FF is a finishing polish and shouldnt be used to correct imperfections. SIP with orange, white, or green is fine.
I realize that SIP is more aggressive than 106FF, but why can't 106FF be used to remove cetain defects? They say it removes up to 2500 grit sand scratches (especially on hard Ceramic), so why would you not be able to use it for a moderate correction? Most car wash micromarring is much finer than 2500 grit level. Couldn't it technically be used to remove 3000 grit sanding scratches in theory (if you wanted to)?
Taken from Menzerna's description of 106FF:
Menzerna Nano Polish is one of two polishes manufactured by Menzerna to remove imperfections in the new, hard, ceramic clear coat paints.
Nano Polish is capable of removing 2500 grit sanding scratches, haze from compounding, light swirls, and mild oxidation while restoring a glassy, smooth shine.
Todd said it well here, Quickie Review: M105 - Autopia Car Detailing Forum
Shoot me a PM if you'd like to discuss it further.
SELF BANNED
Menzerna Polishes Methodology Parts I & II
Part I – http://www.autogeekonline.net/forum/...gy-part-i.html
Part II - http://www.autogeekonline.net/forum/auto-detailing-forum/11444-menzerna-polishes-methodology-part-ii.html
a) For most paint correction PO 106 FA / 106 FF and PO 85 D3.01 polishes (LC White / LC Blue foam pads 1000 RPM) should be all you need.
b) Use PO S34A Power Gloss (LC Purple wool pad 1500 – 1800 RPM) for paint surface correction / renovation.
Alternatve polishes - 3M™ Perfect-It™ 3000 Extra Cut Rubbing Compound, 06060
3M™ Perfect-It™ 3000 Ultrafina™ SE (US) 06068 / Ultrafina SE (UK) 50383
Thank you all. I will give it a try when the weather stops being -20 and post my results
By DapperStyle in forum Auto Detailing 101
Last Post: 03-18-2015, 04:43 AM
By Swift in forum Auto Detailing Tools and Accessories
Last Post: 10-24-2014, 12:41 AM
By BigBill in forum Auto Detailing 101
Last Post: 10-20-2014, 02:43 PM
By emanuel in forum Auto Detailing 101
Last Post: 09-28-2014, 08:10 AM
By Faris63 in forum Ask your detailing questions!
Last Post: 12-30-2013, 01:21 AM
