10-01-2019, 10:50 AM
#2881
10-01-2019, 11:32 AM
#2882
Re: What did you do today, in regards to detailing?
Prepping for winter.
P&S Brake Buster
TufShine cleaner
Duragloss 953 Tire Gel
Wolfgang External Trim Sealant
then the next weekend:
GTechniq W4 pre-foam
Opti Car Wash w/ mitt
clay mitt w/ Immolube
Sonax PNS on all panels except hood
Collinite 915 on hood
Will put on a 2nd coat of PNS & 915 shortly
10-02-2019, 02:54 AM
#2883
Sure did.
Pic of said product.....
As mentioned, for some reason these products have been re-branded recently from Concours to NV.
10-03-2019, 11:46 AM
#2884
10-03-2019, 10:00 PM
#2885
So we had a strange occurence here in Chicagoland...around mid-morning patches of blue appeared in the sky, followed by a glowing orb and no water falling from the sky, so I decided to get after the car a day early, not to mention I'm going to try and get over to my buddy Hectour's house tomorrow after work so he can install my SXTH Element catch can, plus we're going to see my oldest daughter, her fiance and my Grandson this weekend, can't leave the car at home dirty
For today's wash I decided to do an Ech2o RW, using a brand new grout sponge that isn't an Aqua sponge, only because the Ebay'er didn't use the correct photo when selling it, it worked just fine actually. For the tires and wells I sprayed some 303 Tire and Rubber cleaner and then foamed up the tires and wheels with Auto-Fanatic foaming wheel cleaner. I decided to try my Wheel Woolies, I mean I have them but never could use them because of the various wheel designs I've had but this time they worked and worked VERY well, even had to use my medium one for between the barrel and calipers on the front rims. I also scrubbed around the lugs with a designated brush and Mothers Tire and Wheel brush for the spokes, all hands on deck here tonight!
I dried the car with a single Sucker Jr and the finished left behind by Ech2o....just brillant, literally and figuratively Now it's time to head off to bed, 5 a.m. comes around pretty fast!!
2022 Elantra N Cyber Gray
Post Thanks / Like - 0 Thanks, 6 Likes, 0 Dislikes
10-04-2019, 11:58 AM
#2886
Applied some 303 Spray Wax after a Wolfgang rinseless wash. I usually use UQW as an LSP booster but I wasn’t a huge fan of it on my last black car (too much streaking and holograms), so I gave this a try. Easy on and off and no streaks. I did have an issue with the hood bc I was rushing and applied to the whole hood before buffing off, otherwise it was painless. It claims “Up to 90 Days” so I most likely can get away with once a month or a little longer during the winter before spring clean up. I didn’t see much about it here on the forums but the few reviews on Autogeek were very good.
2019 Subaru Impreza Hatch - Crystal Black Silica
2019 Volkswagen Tiguan S 4Motion - Pure White
10-04-2019, 12:06 PM
#2887
Glad you like the 303 Spray Wax, the new and improved formula is truely that
10-04-2019, 12:23 PM
#2888
Initial impressions are very good and I like that it doesn't seem to have any fillers as it didn't cover up any of the random stuff that was there before. Your older posts on it were the final push I needed to pick it up.
I'm interested to see water behavior and I doubt durability will be an issue with my intended plan. It's very cool that it has a slight detailer property to it so light dust wouldn't be an issue.
10-04-2019, 12:51 PM
#2889
Polished the back window of the Ford Focus I maintain. The defects where too deep which I knowned from the start. So was just after to deep clean the glass and if I could reduce the edges of the scratches would be a plus. Maybe it got a very little improvement on it but glass is hard.
3" Shinemate EX603 mini polisher and Carpro Rayon Glass Polishing Pads.
Carpro CeriGlass
Sonax Glass Cleaner as the clay lube and a clay block.
Full speed setting on the polisher and was able to build up heat on the glass. So a little bottle of destilled water to spray on while I polished as the CeriGlass dryed quickly. And also for spray it on when I removed the polishing residue. Got a bit late so since it's 24/7 outside I wait until tomorrow to apply the Aquapel on it. And will see if I can polishing the windshield too. The cleaning was necessary as not even a claying with the glass cleaner got it clean enough. The difference was when I sprayed the water on the glass it where flat water standing on it and where I had not polished you saw it blotchy. Goal reached to get a deep cleaned glass.
10-04-2019, 01:28 PM
#2890
Kicked it old school today. Not old products per say but products I haven't used in quite a while. Cleaned the wheels with Mckees foaming wheel cleaner gel and the tires with McKees tire and rubber. Wheels wells got Meguiars D101. Paint was washed with Duragloss 501. Not as good as Reset of course nor OPT car wash but still pretty good. Has a Cherry Nyquil scent straight from the bottle but ince diluted it smells okay. Rinses clean. Blew off most of the water then proceeded to dry with TRC Pluffles with 303 Speed Detailer. (Klasse mentioned this the other day and I had a bit left so I pulled it out.) Tires got PERL as always. Jammed were cleaned with N 914 and put some OPT Car Wax and that was that. No real pictures but I did do a couple "sick modz." Just a couple of vinyl pieces from a company called Badgeskins.
By VISITOR in forum Off-Topic
Last Post: 04-29-2024, 01:19 AM
By Driwash in forum Show N' Shine
Last Post: 10-13-2021, 12:29 AM
Last Post: 10-05-2018, 10:57 AM
By Cruzscarwash in forum Off-Topic
Last Post: 03-28-2017, 07:06 PM
By OCDetails in forum Show N' Shine
Last Post: 03-25-2006, 09:20 PM
Members who have read this thread: 114
- Agent6er,
- RPPM,
- 11Silverado,
- jamesss35,
- TNMIKE46,
- PeteT19640,
- Tbonem3,
- vaced,
- mikeinauburn,
- Dyerlog,
- KirkH,
- georgia boy,
- 70fastback,
- The Guz,
- fastfreddy,
- Prange,
- bcarte3,
- PouncingPanzer,
- jstollar,
- LSNAutoDetailing,
- XSR,
- barryscott,
- Vegas1,
- UncleDavy,
- waddell64,
- jedi kid,
- Big Dave,
- craigdt,
- Bosko,
- vobro,
- FocusSTguy,
- Rsurfer,
- Eidos71,
- tgame80,
- PaulMys,
- aannatshlzea6696,
- 02whitetundra,
- MidnightNarwhal,
- Avadesh Nathan,
- davidwjohnson,
- ev780,
- DUBL0WS6,
- vaca22,
- mengelhardt,
- Forty,
- miatadriver,
- rackeu,
- BTW574,
- vlamimc,
- chefwong,
- Ace22,
- 98CayenneTA,
- Sfs4567,
- Jeffrey16,
- Yancy,
- aaustinfranesoz7344,
- larr12,
- dlc95,
- Maklingler,
- MCarter88,
- Torsion Tool,
- boosteddub69,
- DG3.7,
- Tasmania,
- Jplouch,
- Jimbosan72,
- JerryL,
- Icarus,
- Dan K,
- TTQ B4U,
- CleanIT,
- Azure,
- Nav45,
- Epilogts,
- VISITOR,
- D.BRITT,
- Urmil,
- mc2hill,
- AndyA6,
- mikescardiaries,
- kjoejoe,
- oneheadlite,
- Wknd Dtlr,
- chadkintz,
- Dirty Harry,
- Desertnate,
- BudgetPlan1,
- msharpe785,
- YMMV,
- Gridlink,
- Odrapnew,
- brianshaeffer,
- Texchappy,
- dbeng,
- MisterSnoop,
- dprichter,
- AMarkham40,
- John U,
- DFB,
- rmtaylor51,
- cb804,
- Kneel,
- PA DETAILER,
- bill walsh,
- kappy,
- hansen97,
- Optimus Grime,
- chilly,
- SNP209,
- Silly Rabbit,
- bapatickmjnra7168,
- Karl_in_Chicago,
- Setec Astronomy,
- DanaDetailingPros
