Page 3 of 3 FirstFirst 123
Results 21 to 30 of 30
  1. #21
    Mar 2011
    PA
    5,793
    Re: How to remove Klasse AIO? Causing wiper chatter
    2018 Colorado ZR2
  2. #22
    Sep 2016
    128
    I completely gave up on glass coatings. Because of traffic film and water spots, I could never get a clean windshield with any glass cleaner once rainy season starts. So I lightly polish the windshield with water spot remover or Griot's glass polish to get it clean every few weeks, and then went back to Rain-X of all things.
  3. #23
    Super Member Finick's Avatar
    Jul 2017
    885
    Quote Originally Posted by gspam1 View Post
    I’ve had good luck with rainx, as well. The water behavior is freaking awesome.
    It’s super easy to work with if you give your windshield a fast once over cleaning before you wash your car, and then apply two coats and let it sit while you set up for a traditional or rinse less wash. I’ll polish my windshield every so often just to remove and road grime and film that builds up, but it’s not done on a schedule.
    The haze comes right off as you wash. I usually find it lasts like.. 2 months or so of decently strong beading, and then starts to die off pretty hard. It’s so easy to reapply though I have issues even thinking about investing in a glass coating that I have my doubts will really hold up in my harsh(er) environment.
  4. #24
    Nov 2015
    Arizona
    1,419
    I'm thinking this may be causing my wiper chatter with Aquapel. The "up" swipe is smooth. It's the "down" swipe that chatters. So, I think the glass is so slick that it doesn't allow the wiper edge to "flip" back in the other direction. Up swipe it pulls the blade... down swipe it pushes the blade, resulting in chatter.
  5. #25
    Nov 2015
    Arizona
    1,419
    See this video about bending the wiper arm to stop chatter. Makes sense.
    YouTube
  6. #26
    Nov 2015
    Los Angeles, California
    13,765
    Quote Originally Posted by AZpolisher15 View Post
    But even with new wipers I get some chatter. Funny thing is that when dry, the wipers glide just fine. And when it rains, the first few swipes are smooth. But after about 15 seconds the chatter starts.
    This is exactly what I experience... I bought brand new wipers straight from the Cadillac dealer, they work outstanding for clearing the morning dew, but once they saw actual rain they did exactly what you describe. It’s frustrating.
    Btw this is with no sort of coating on my windshield.
  7. #27
    Junior Member vincec's Avatar
    Aug 2016
    Claymont, DE
    77
    I've been using Pinnacle GlassCoat Window Sealant with Rain Repellent on three vehicles since they were new. Two with OEM factory wiper blades and one that was changed to Bosch ICON's. I'm applying this every 3 months or so and getting good water beading until the next application. I just applied to all the glass on all three vehicles yesterday.
  8. #28
    Nov 2015
    Arizona
    1,419
    I think it's the slickness if the coating combined with the pressure of the arms. The blade edge isn't "flipping" when changing directions.
  9. #29
    Mar 2011
    PA
    5,793
    UPDATE....
    The problem may be a bent wiper arm. To make this diagnosis, bring the wiper up to mid-stroke on the windshield and examine the blade assembly. The blades should be making full contact on the windshield and the blade arms should be parallel to the glass. If the arm is bent, use some pliers to carefully twist it until it is parallel with the glass again.
    How to remove Klasse AIO? Causing wiper chatter-wiperarmfix-jpg
    Did this yesterday morning. 100% better! Guess after 6 years, they needed a tweak. Both needed a slight bend downward. You want the rubber part of the blade to move on the downstroke stroke and back the other way on the upward stroke. Had plenty of rain yesterday and they worked great. PUT A CLOTH OVER YOUR WIPER ARM so you don`t scratch the paint on the arm!
    2018 Colorado ZR2
  10. #30
    Nov 2015
    Arizona
    1,419
    Same here. I bent the arm by hand very slightly. It alleviated the chatter on the down swipe! Very happy to have discovered this solution.
  1. Replies: 14
    Last Post: 01-30-2022, 09:35 AM
  2. How the heck do you stop wiper chatter?
    By Brandon1 in forum Auto Detailing 101
    Last Post: 08-12-2016, 12:24 PM
  3. New car: How to remove wiper outline?
    By flycaster in forum Ask your detailing questions!
    Last Post: 07-31-2013, 05:57 AM
  4. Wiper Chatter with New Blades??
    By polycat33 in forum Auto Detailing 101
    Last Post: 06-07-2013, 04:01 PM
  5. Wiper Chatter
    By 1883atlantics in forum Off-Topic
    Last Post: 02-28-2007, 03:11 AM
