Re: Resin On My Hood
This may be a long shot, but have you ever cut a run out of clear coat with a razor blade.
If not i understand, it's process used by painters to quickly knock down the bulk of a run before sanding and buffing.
My guess is it wil need cut down sanded then polished. If that's not something you are comfortable doing yourself
Maybe find a trusted painter in your area, it shouldn't be to that difficult for most experienced paint and body people .
Post Thanks / Like - 1 Thanks, 1 Likes, 1 Dislikes
Originally Posted by
Strong66
I found this video online. Is this a process I should try, with the razor blade?
YouTube
The anticipation of death is worse than death itself!
I have never used the technique in that video, it could work if the resin isn't bonded very well.
Thats not the technique I've used, and I'm afraid me trying to explain how to do it would be confusing at best.
I'm guessing since that product is designed to stick to glass it has a pretty solid bond. I think Strong's method is probably your best shot.
2015 F-150 Crew Cab Lariat
2016 Chevrolet Camaro 2SS
I contacted the detailer in the video I posted and talked to him about the resin on my hood. He explained to me how he does his removal with a razor blade and how I should prepare my razor blade to do the same. He stated that it should take the resin off. I will keep you posted.
