Results 11 to 20 of 21
    Super Member Sizzle Chest's Avatar
    Apr 2011
    Naples, FL
    5,897
    Re: I use the tornado and I recover door vinyls
    Nice work! It really cleaned the door panel up nicely!
    Scott Harle
    Autodermatology
    #autodermatology
  2. Thanks Gustavocanetemdp thanked for this post
    Likes Gustavocanetemdp liked this post
  3. #12
    Super Member FrankS's Avatar
    Jul 2013
    West Palm Beach, FL
    1,560
    Nice work Gustavo!
  4. Thanks Gustavocanetemdp thanked for this post
  5. #13
    Junior Member roswell630's Avatar
    Apr 2010
    Charlotte, NC
    35
    So what is actually penetrating the fabric? What about electronics in the door, not to mention high quality speakers we've spent long hours putting in?
    Sent from my SM-N950U using Tapatalk
    DMac
  6. Likes RippyD liked this post
  7. #14
    Newbie Member Gustavocanetemdp's Avatar
    Jun 2018
    Quote Originally Posted by roswell630 View Post
    Hi roswell630, The expelling liquid is pulverized and is not in large quantities, the cleaning effect is achieved by the correct APC used and the Tornado spin effect that gives the tool
    Enviado desde mi iPhone utilizando AGOnline
  8. Thanks roswell630 thanked for this post
  9. #15
    Apr 2010
    Charlotte, NC
    35
    Quote Originally Posted by Gustavocanetemdp View Post
    Well that looks awesome! I had no idea that was around. Ill be looking into it. Thanks!
    dmac
    DMac
  10. Thanks Gustavocanetemdp thanked for this post
  11. #16
    Mar 2011
    PA
    5,792
    Quote Originally Posted by LSNAutoDetailing View Post
    Gustavo, you are absolutely correct. The Tornador (with the right APC or solution) is an amazing invaluable tool. If you haven't already, look at their shop-vac attachment kit. It's great if you don't have a carpet extractor.
    What is this shop vac attachment kit? Looked in the store. Could not find it.
    2018 Colorado ZR2
  12. #17
    Super Member RippyD's Avatar
    Jan 2016
    Portland, OR
    1,247
    Been looking at this tool. Can somebody help me understand what it will do that a APC with a brush won't? Is it just faster, or does get out dirt that can't other wise can't be? Also curious about the shop vac attachment. Can't really invest in an extractor, but would like to extract grime from carpets.
    2006 LR3 White // 2014 Boxster Agate Gray // 2012 Sentra Aspen White
    Sealant test resultsxxxxxDilution ratio chartxxxxxWheel cleaner info
  13. #18
    Jun 2014
    Chandler, AZ
    3,360
    Quote Originally Posted by RippyD View Post
    It evicerates dirt. Best to just watch you tube vids to get the idea.
  14. Likes Gustavocanetemdp liked this post
  15. #19
    Jan 2014
    SoCal
    1,122
    Just because no one has mentioned it yet - the Tornadors require a significant amount of air volumn (at close to the high end psi of 90 if you want it to reach it's potential). Don't think you're going to get any work done with anything less than a 30 gallon set up. You would be taking forever. Even on most 30 gallon setups, good luck keeping it at 90 psi while you work.
    I bought a two stage compressor (peaks at like 150 something psi) with a 5hp motor and 60 gallon tank to run my tools. It may be more than needed, but will always get the job done.
    If you want to try running these tools off one of the various 30 gallons available, I would strongly suggest you look for a compressor that pumps to 120psi. Like I said before, it works best if you can keep it near 90 psi as you work. The 30psi slack would greatly help.
  16. Likes Gustavocanetemdp liked this post
  17. #20
    Super Member sudsmobile's Avatar
    Jan 2018
    IE, SoCal
    970
    Pretty much rules it out for mobile guys. I've looked into it and it just doesn't seem feasible.
  1. School me on marine grade vinyls?
    By agarabaghi in forum Auto Detailing 101
    Last Post: 08-05-2013, 11:21 PM
  2. Cleaning the felt between door and door panel?
    By nissenc1337 in forum Auto Detailing 101
    Last Post: 04-01-2013, 05:08 PM
  3. Waxing over vinyls, afraid to pull up
    By MatthewM in forum Auto Detailing 101
    Last Post: 08-20-2011, 05:52 PM
