Re: HD Speed vs Megs D166 vs Menz 3 in 1
Originally Posted by
custmsprty
Speed preferred being used with a more aggressive machine and pad combo. A green B & S pad pretty much does nothing with Speed. I use orange B & S or LC, but prefer B & S with Speed.
Thanks for the post!
Bingo. When I first tried Speed, it was with an LC flat white pad. After a test spot, I could tell I wanted more correction. Put on an orange LC flat, and off I went.
This year, I'm trying Speed with some Thin Pro LC's
Ronin47
Great from now on end will use it with BnS Orange and Megs Maroon. Have you or anyone else tried it on the Rupes Yellow? Me thinks should be similar results as BnS Orange.
Meguiars doesn't even recommend using those maroon pads because they create so much heat
fightnews
Never had an issue, those pads are amazing.
fightnews
That was the old version. The new ones are very open, dense, and "airy". Kind of like a green Rupes pad.
