Re: What is on my tires?
The technique that I use and that has worked very well has been to use steel wool grade 0000, it must be done with a dry tire and then I proceed to wash it in the traditional way. A single steel wool can clean all four tires but if they are too sticky you may need two. This procedure does not harm your tires if you do it carefully.
^^ I've also used 0000 Steel Wool with Bleche Wite to get the super gummy junk off... It usually ends up blooming the tires, but nothing a little PB World Bold N Bright won't take care of to make them look perfect again.
Originally Posted by
Eldorado2k
LA’s Totally Awesome Cleaner.
Oh yeah?? Well NYTA is better. Lol
Cool tip, Eldo my man!
