Re: Finishing Polish For Soft Paint
Probably another which would work well, would be Wolfgang Finishing Glaze.
I've used it, and as others have informed us folks, the "Glaze" name is a misnomer, it is actually an extremely fine last step ultra finishing polish, about the equivalent I believe to Menzerna 3800-4000.
With a soft foam finishing pad, this has always worked for me on very soft paints.
And you're correct, it's not a "glaze", that's meaningless word in our industry now days. It's a fine cut polish.
Originally Posted by james751993
When it comes to soft paint what finishing polishes and pads do you guys use to achieve a haze-free finish?
-James
Are you going to install a coating?
If not, then get some Blackfire One Step and use like a finishing polish. You can always top it with a dedicated wax or sealant for more protection.
If only the name of a product was the same across the board !
I will most likely install a coating in the next 2 months or so. Probably CQuartz.
Did you think of carpro reflect or essence if you are going to a coating ?
UPDATE: I decided to start my testing with Menzerna SF3500 since it was a product I could get my hands on quickly. Just as soon as my search began it finished. 3500 finished BRILLIANTLY on the paint with zero marring using a LC CCS black finishing pad. From what I have read, 3500 uses diminishing abrasives so I experimented with amount of passes and machine speed. The best method to remove most blemishes was 4 speed on the polisher and 5 passes over the section.
Thank you to everyone for their input.
-James
-James
Great to hear that you got it sorted out.
-James
Very happy that you have gotten the results you were seeking, that's good news.
I'm very sorry and apologize to you, that when I followed along, and responded to you here, I never looked to the left and noted your location. My fault, not yours.
That due to location, it may not have been an easy matter getting detailing supplies from the USA. I'm hoping my mention of Menzerna and comparing the Wolfgang products to them that a light went on and that you then knew what to seek for a Polish to get the job done.
It is my understanding that the Wolfgang Polishes are indeed made by Menzerna, perhaps from their USA located Facility, and/or marketed for the USA.
I'm not sure how many other PBMG house brand's products and Polishes may be made by them, but I can attest that all their product lines are totally first class in every way.
Best of luck!
Best of luck!
Nah, no offence taken mate your suggestion solved my issue.
We do have a few suppliers here that can get products that PBMG stock. I went with Menzerna as the supplier had a shopfront that was close to my home. For some reason I cant find a supplier for SF3800, even on the Menserna Australia website it makes no mention of it. I would have preferred SF3800 in following the 'use the least aggressive method to get the job done' but only SF3500 is available locally. Maybe I'll order some off Autogeek once my shopping list grows to make the shipping cost worth it.
-James
By heinzbush in forum Auto Detailing 101
Last Post: 01-17-2019, 11:07 AM
By craigv in forum Auto Detailing 101
Last Post: 10-24-2018, 09:15 PM
By Sushi5679 in forum Auto Detailing 101
Last Post: 04-14-2018, 10:18 AM
By smbstyle in forum Rotary Buffers
Last Post: 05-21-2013, 06:02 PM
By WRAPT C5Z06 in forum Product Reviews
Last Post: 08-14-2011, 07:53 PM
