Page 2 of 6 FirstFirst 123456 LastLast
Results 11 to 20 of 53
    Dec 2017
    228
    Re: Anyone else ditches the 2 bucket method?
    Quote Originally Posted by MikeC78 View Post
    If you don't use the same mitt, then where are you pulling them from? The dry shelf? No thanks! I'd rather keep mine soaked in a bucket of soap. That guy is too dramatic for me in that video.
    Yeah you're right. I guess I'm also trying top find an excuse for buying a foam gun. Hahaha
    May 2014
    449
    Look up the Gary Dean method. Yes. I fill a bucket with mitts/towels and fill it up with a soapy solution. Same if I was doing rinseless wash. I pull out a clean soap soaked mitt and wash a panel. Dump the mitt in the second bucket of water and pull a clean mitt from the first for my next panel. But yes, I keep the panel I'm washing wet or sprayed with rinse-less solution while I wash.
  3. #13
    May 2014
    449
    Nothing wrong with a foam gun. I use them initially as a pre-soak sometimes when I have a filthy vehicle.
  4. #14
    Super Member Finick's Avatar
    Jul 2017
    885
    Whenever I do a traditional wash, I just use a single bucket.
    I admittedly have a grit guard at the bottom, but only because I’ve had it for years and years. I think my friend may have given it to me if I’m not mistaken.
    I will either use a garry dean method with towels, or I’ll use my boars hair brush. I’m aware of the taboo nature of even saying that I use a brush but I promise you, I have never noticed any scratching from my brush. When properly maintained I think it’s been one of my best investments for detailing (I’ve had mine since 2007/8 I think.)
    My rationale for not bothering with a rinse bucket is that; if I was able to agitate the dirt off the surface without scratching, whatever I *might* have a chance of picking up when I go back in for more suds should be a non issue.
    I do plan on getting some mitts though so I can try out using those vs towels or my brush.
  5. #15
    Sep 2016
    128
    No buckets. I use a rinseless wash mitt that releases dirt easily and a pressure washer with the machine gun grip with no lance, and a #40 tip. I keep a small squeeze bottle of car soap in my shirt pocket. I squeeze the soap into the mitt, blast it and the car with the pressure washer, and continuously rinse the mitt and car and add soap as needed. If I ever dropped the mitt, I would simply grab a fresh one and keep going. If I'm not using the pressure washer, then I do the same thing with a foam gun attached to the hose. The mitt rinses a lot cleaner being blasted by the pressure washer than it does being dipped in a rinse bucket.
  6. #16
    Super Member Bill D's Avatar
    Mar 2006
    The First Coast of FL
    2,376
    I've been washing with a foam gun and multiple mitts long before the Gary Dean Method. I learned to wash from Accumulator; who has the best wash technique I've ever read about.
  7. #17
    Jul 2016
    3,328
    Quote Originally Posted by TheMidnightNarwhal View Post
    Yeah sorry the video is long but the point that came to mind is why use buckets if you have a foam cannon or gun right? You can always get clear dirt free water and soap from it as you go.
    No you can get foam u can't get water. Getting rid of the 2 bucket wash is no good and I have a foam cannon. That's like telling the church to get rid of the cross
  8. #18
    Nov 2015
    Los Angeles, California
    13,765
    I’ve never needed a rinse bucket to wash... All I need is 1 bucket full of mitts and an empty bucket to toss them into as I grab a fresh 1.
  9. Likes Hammer77, Frank70, 6od liked this post
  10. #19
    Jul 2016
    3,328
    Isn't it more productive to just use 1 or 2 mitts and a rinse bucket? It only takes 30 seconds to fill a rinse bucket and then you won't have all those mitts to wring out and put through the washing machine.
  11. #20
    Nov 2015
    13,765
    Quote Originally Posted by fightnews View Post
    No.
    Reason being is if I were to only use 1-2 mitts I’d have to constantly waste time bending down and repeatedly dunk my arm into a bucket of water and closely inspect the mitt to ensure it’s clean enough to use again.
    Not to mention, with all that extra time I’m wasting I’d also be giving more time for soap to possibly dry on the panels, which is never a good thing.
    On the other hand: If I have multiple mitts, I can grab 1, go over a panel with 1 side, flip the mitt and go over the panel once again to ensure it’s 100% clean and toss it into my empty bucket and grab the next mitt and continue washing the next panel and so on... Never stopping, never wasting time, never having soap dry on the vehicle, and never getting distracted.
    Rinse all the mitts with the hose nozzle [which does a better job at getting them clean] as soon as I’m done with the wash and put the lid on my bucket and proceed to rinsing the soap off the vehicle. IMO It doesn’t get any easier.
    I don’t wring the mitts out. I usually just leave them in the clean soapy water with a lid over the bucket. Washing a load with several microfiber items is more productive than washing only 1-2 mitts per load.
  12. Likes PaulMys, 6od liked this post
  1. Is this the one bucket method?
    By 57BORNTORUN in forum Off-Topic
    Last Post: 01-15-2014, 12:39 PM
  2. 2 bucket method done right
    By gothamite302 in forum Off-Topic
    Last Post: 03-23-2013, 08:39 AM
  3. Two Bucket Method Q
    Last Post: 01-27-2013, 08:38 PM
  4. 2 Bucket Method???
    By djrazr in forum Auto Detailing 101
    Last Post: 03-21-2008, 03:18 PM
  5. 2 bucket method, What is it?
    By tnbug4me in forum Auto Detailing 101
    Last Post: 06-24-2007, 11:30 AM
