Can I use my DA to sand?
I need to sand a rust spot down and was wondering if I should buy a drill attachment sanding pad or I can use my DA.
But DA you can't really put pressure right to sand since it stops spinning?
Re: Can I use my DA to sand?
I would buy a panel from a salvage yard to practice on first and get the results through practice
Why would I need practice? I'm just sanding down to bare metal.
Oh. See what your da can do then
Okok.
But yeah I was wondering though is DA doable to sand like, because if you put to much pressure it stops spinning and just orbits right?
I would try. If your da stops, maybe consider a rotary or a palm sander
I might just getting drill attachment. My drills are wireless so would be easier.
What matters is you try. Once you have a method and tool, progress will be made
DAs are use to sand everyday in auto body shops although they are primarily air-powered versions.
If your DA is a FLEX 3401 you can sand with it!!!! Lets see the (ready for the fanbois to come out of the woodwork?) Rupes do that!!!!!!!!!!!!!!
But seriously the 3401 can sand because it is direct drive DA
By vettefever17 in forum Wet-Sanding, Cutting & Buffing
Last Post: 06-18-2016, 04:20 AM
By Gcleov in forum Wet-Sanding, Cutting & Buffing
Last Post: 02-14-2016, 10:34 AM
By queens guy in forum Auto Detailing 101
Last Post: 07-30-2013, 02:01 PM
By Royaldetail in forum Wet-Sanding, Cutting & Buffing
Last Post: 06-07-2012, 01:38 PM
By courtdale in forum Auto Detailing 101
Last Post: 09-19-2011, 10:35 AM
