Re: CSL or Cosmic V2
Any experience with Master Sealant? I am looking at Cosmic V2, Master Sealant and Carnaubaflockencreme Famous to purchase just not sure how all these 3 fit together or should be used seperately?
Originally Posted by
Ronin47
I’m talking more about actual, hard 9H coatings not toppers. Currently am happy with my Reload/Ech20 mix so not too interested in looking elsewhere from a spray sealant wipe on wipe off perspective. My post is more wanting answers from those experienced with either or both CSL or Cosmic V2 where I’m hoping someone on here will state XXX was noticeably glossier than YYY or XXX sure did add something extra to the paint after correction.
Do you want gloss or an application method. You just said yourself those type of coatings don't add much in the looks department. Then your not even supposed to top them that much. No car is going to look it's best/ glossyest after not being topped after 4-6 weeks. U want gloss u gotta be on it all the time.
fightnews
Collinite 915 held its gloss for 6 months, as did Essence,Essence Plus,Reload combo as did WGDGPS 3.0(all of which are superior in looks to any coating I have used). I know PA’s durability claims are far fetched but if their pricy products I have singled out can give me 6 months too as opposed to the 12-15 month claims I am more than content.
Ronin47
Totally different products
I have all of them.
I'd suggest reading the manufacturers descriptions and uses, it's all posted on AG's product descriptions.
Polish Angel Master Sealant
2019 Nissan Rogue SL
custmsprty
I have all of them.
From your experience which gave the best look? If you had to put them in order of gloss 1-3 with 1 being the highest.
Ronin47
Personally, I don't think PA's durability claims are any more far fetched than any other makers products I have used.
custmsprty
POLISHANGEL recommends two coats of COSMIC applied 2 hours apart.
I machine apply PA you get total coverage and use very little. This was Viking Coat. I barely dented the bottle
Attachment 62706
Attachment 62707
It goes on like wax right?
fightnews
Like a sealant, that's the beauty of it, then you let it dry and just wipe it off. As I've mentioned before, this stuff goes a long way. I used very little. That's a 4" BS pad on my Duetto. The pad gets saturated and you need less and less as you go along.
fightnews
It goes on like a liquid wax or a sealant. A very creamy consistency. It can be applied by hand with a foam applicator (which PA includes in the kit), or machine applied as custmsprty does. I use my GG3 with a LC 3.5" ThinPro red waxing pad to apply both Cosmic and Viking Coat. Works very well and minimal product is needed.
Al Schmidt
"Adventure, is a car called Riviera..."
PA Master Sealant with 3 layers of High Gloss Spray applied in October is still going quite strong on my personal car. And we've had an unusually long and wet winter. It's been very durable for me. High Gloss spray is just amazing looking. Beads, sheets and repels dirt better than Reload. No contest for me.
I want to try the Carnaubaflockencreme Famous with its special primer next. Sounds like that will have the best looks
