Page 1 of 5 12345 LastLast
Results 1 to 10 of 48
    Oct 2016
    In your back yard
    89
    Do you prime each pad before use when correcting or polishing?
    I was watching a how to use your flex 3401 vid by Mike Philips and he said to prime each new pad by smearing product your using over the whole pad face and then the few drops and that's what your going to use.
    Is this done only with brand new pads for its first use or before you begin using each clean pad. It just seems like a lot of product especially since you should have 8 pads to correct a full size car.
    Just want to be sure on this....
    Thanks guys
    Nov 2015
    Los Angeles, California
    13,783
    Some people subscribe to that method and others don’t. These days it’s considered the proper way to start off a fresh pad..
    I personally never prime foam pads. Never.
    I’ve always preferred the circle of product method when starting off a fresh foam pad.
    IMO a circles worth is always the sweet spot to start a pad off right. From then on 3-4 pea sized dots is all you need.
    Anything less is not enough and results in too dry of a start.
    But IMO priming the foam pad + adding 3-4 dots on top of that is overkill and can lead to premature saturation of the pad which is not good for anything.
    With a circle, the whole pad is evenly covered in product within the 1st few seconds anyway, without running the risk of clogging up the pores from the start.
    The only time I prime pads is when I’m using microfiber pads.
  3. Likes lalojamesliz, dlc95, Frank70, PaulMys, mwoywod liked this post
  4. #3
    Oct 2016
    In your back yard
    89
    Re: Do you prime each pad before use when correcting or polishing?
    Sweet. Thanks man
  5. Thanks Eldorado2k thanked for this post
  6. #4
    Super Member dlc95's Avatar
    May 2013
    Rochester Hills, Mi
    6,018
    I'm very similar to Eldo.
    I usually start with 3 to 5 dots of product on foam pads, and reload with anywhere between 2 and 4 dots - depending on the pad/liquid I'm using.
    I do however, prime microfiber pads.
  7. Thanks Eldorado2k thanked for this post
    Likes BudgetPlan1 liked this post
  8. #5
    Jul 2016
    3,328
    It doesn't take as much as you think to butter the pad. You spread it real thin
  9. #6
    Oct 2016
    In your back yard
    89
    When I first did my SUV with my pc7424xp I was following directions from chemical guys with 4-5 drops and a spray of pad conditioner usually just on a clean pad right before it got used
    Do any of you guys ever use pad conditioner or something similar? I think it's like claybar lube
  10. #7
    May 2013
    Rochester Hills, Mi
    6,018
    Quote Originally Posted by lalojamesliz View Post
    Not unless I'm using foam on a rotary. That's an old carryover from the directions on the Meguiar's bottles.
  11. #8
    Apr 2015
    PGH, PA
    1,482
    I don't prime my foam pads
    I do 5 peansize dots then 3 after which is always on a new spot.
    Never had any issues with cutting nor finishing
  12. Likes Eldorado2k liked this post
  13. #9
    Super Member PaulMys's Avatar
    Jan 2014
    Eastern L.I. NY
    10,772
    I'm in agreement with Eldo on the circle.
    When I started out, I tried priming the pad first. Led to premature saturation of the pad IME. Then I tried just the 3 pea-sized dots. Didn't seem like quite enough product. (Again, IME).
    Then I thought to myself: Why not put a thin bead around the whole pad?
    Bingo. It worked for me, and that is my method now. The circle method has worked for me using LC flats, Thin Pros, and B&S.
  14. Thanks Eldorado2k thanked for this post
  15. #10
    Super Member rangerbay's Avatar
    Jun 2017
    Enterprise, Al.
    297
    I prime real coarse cutting foam pads. On medium cut or smoother, I just put an x for the first pass, then pea sized drops after, depending on what I'm doing. I do not condition rotary foam pads, it will just sling it all over you!
    Bill
  1. Replies: 12
    Last Post: 03-07-2019, 02:51 PM
  2. Gyeon Prime
    By Dave Hamlin in forum Ask your detailing questions!
    Last Post: 01-17-2017, 02:24 PM
  3. Some questions about correcting/polishing
    By Nav45 in forum Auto Detailing 101
    Last Post: 02-22-2016, 09:50 PM
  4. How to Prime a LC CCS Pad
    By Thumpr in forum Ask your detailing questions!
    Last Post: 04-20-2015, 03:30 PM
  5. Polishing/Correcting Glass
    By lempilot in forum Auto Detailing 101
    Last Post: 08-19-2008, 11:40 AM
