Page 2 of 5 FirstFirst 12345 LastLast
Results 11 to 20 of 48
    Super Member Paul A.'s Avatar
    Dec 2007
    Tampa Florida
    5,274
    Re: Do you prime each pad before use when correcting or polishing?
    I use Mike's method and retire each pad much earlier now compared to my old method of 3-5 dots or thin x pattern. Because I have adopted Mike's priming method I'm using a lot more pads per job but my results have improved.
    I do like the logic of having as much product working each section. I'll go 2, maybe 3 sections and swap out and prime a fresh, clean pad and have seen firsthand results improved.
    I'm trying to convince anyone...just my experience.
  2. Likes PaulMys, derass liked this post
  3. #12
    Super Member PaulMys's Avatar
    Jan 2014
    Eastern L.I. NY
    10,772
    Quote Originally Posted by Paul A. View Post
    Exactly Mike's point of "Find something that works, and stick with it".
    All of us have adopted our own methods, and we like to share those with the AGO crowd.
    Funny thing is, it is all these methods that both inform and drive a newbie completely insane at the same time. (Speaking from experience). Lol
  4. Likes rangerbay liked this post
  5. #13
    Super Member dlc95's Avatar
    May 2013
    Rochester Hills, Mi
    6,020
    I tried it a couple times - even recently, and it worked very well!
    I used M100 with some standard orange LC flats, which seemed like the perfect type of pad for that priming method.
    The green Buff and Shine pads I use to cut have a more open cell structure, which just ends up getting over saturated using that method, very quickly.
  6. #14
    Jun 2013
    Montreal, Quebec
    3,996
    Yes, I always prime the pad. You can work without doing it, but the problem is that the areas on your pad without product on it will not be working to correct or polish. So if half your pad has no product on it, you are only 50% effective meaning it will take you twice as long to achieve the same result. Up to you
  7. Likes derass liked this post
  8. #15
    Nov 2015
    Los Angeles, California
    13,806
    Quote Originally Posted by Calendyr View Post
    Isn’t it impossible for that to actually happen? I mean if that were true, there’d be open gaps when you go to wipe off the polish.. And since there’s never any dry gaps when wiping off, then that means that even the dry areas of the unprimed pad have come in contact with the polish within the 1st couple of seconds of you turning the polisher on.
  9. Likes BudgetPlan1, fightnews, dlc95 liked this post
  10. #16
    Nov 2015
    13,806
    Here’s the same pad that I posted a picture of earlier in this thread. [yes it’s been laying around dirty for the past 10 days] I used this 1 pad to polish the whole car [Cadillac CTS]
    Notice how the circle where I initially applied the polish is easily visible and it’s the only area of the pad that could be described as “overly saturated” whereas the rest of the pad remains pretty fresh [especially considering it was used to polish an entire vehicle]
    -If I had primed the whole face of the pad I’d most likely be looking at the entire surface being over saturated to the point where it’s no longer usable. But since I didn’t prime the pad, it allowed the pad to remain fresh for much longer, with just the right amount of moisture from the polish to be effective without ever coming close to clogging the pores. [cleaning on the fly is vital]-
    Some people may scoff at the fact that I only used 1 pad to polish the entire vehicle... But 1st of all, this is a 7” pad. It covers a much larger area compared to a tiny 5” pad.
    Plus I was polishing a vehicle that’s already in near perfect condition, so there was no heavy duty stuff going on.. I was simply polishing to max out the gloss on the paint. And my results are good.Do you prime each pad before use when correcting or polishing?
    Contrary to popular belief, I don’t have to go through a Ton of pads for a simple quik polish of the vehicle. IMO Not priming the foam pad is a major+ and also results in a better user experience.Do you prime each pad before use when correcting or polishing?
  11. Likes dlc95, mwoywod liked this post
  12. #17
    SELF BANNED
    Sep 2017
    570
    The polish is meant to be on the paint surface more than the face of the pad. You actually reduce cut with a primed pad as you have a more slipping surface than a working surface. I never ever prime pads.
  13. Likes BudgetPlan1, dlc95, mwoywod liked this post
  14. #18
    Jul 2016
    3,328
    Me too!
    I don't agree with your method but Can't argue with that. Is it possible you would have gotten better results with more pads?
  15. #19
    Jul 2016
    3,328
    Quote Originally Posted by Ronin47 View Post
    Can you prove that? I say "You actually reduce cut" by not priming the pad because you have less abrasives.
  16. Likes dlc95 liked this post
  17. #20
    Jul 2016
    3,328
    Quote Originally Posted by lalojamesliz View Post
    When I first did my SUV with my pc7424xp I was following directions from chemical guys with 4-5 drops and a spray of pad conditioner usually just on a clean pad right before it got used
    Do any of you guys ever use pad conditioner or something similar? I think it's like claybar lube
    I use it sparingly
  1. Replies: 12
    Last Post: 03-07-2019, 02:51 PM
  2. Gyeon Prime
    By Dave Hamlin in forum Ask your detailing questions!
    Last Post: 01-17-2017, 02:24 PM
  3. Some questions about correcting/polishing
    By Nav45 in forum Auto Detailing 101
    Last Post: 02-22-2016, 09:50 PM
  4. How to Prime a LC CCS Pad
    By Thumpr in forum Ask your detailing questions!
    Last Post: 04-20-2015, 03:30 PM
  5. Polishing/Correcting Glass
    By lempilot in forum Auto Detailing 101
    Last Post: 08-19-2008, 11:40 AM
