Page 4 of 4 FirstFirst 1234
Results 31 to 34 of 34
  1. #31
    Super Member The Guz's Avatar
    Jun 2013
    LA, CA
    8,719
    Re: What is the right cquartz coating combo?
    Quote Originally Posted by desidetailer View Post
    Thanks for the info..
    What I meant was a member used 3 coats cq siO2 then topped it up with 3 coats of cq uk and then topped it up with 2 coats of gliss... yup you maybe right that I might be a lil overthinking but just wanted to clear my doubts... are these combo really that better or its just the OCD and having a single type of coating and then topping it up every 3-4 months with reload is sufficient?
    I completely missed this post. But this is way overkill. No need to go with this many coats. The law of diminishing returns pertains to coatings just like wax.
    I recall reading that after around 3 coats the coating does not bond to itself any more and that each coat is then removed essentially adding no benefit. Just what I read and heard.
    In most cases one coat is fine. 2-3 max depending on the manufacturers recommendations.
    Nice...
    Here’s Corey’s confirmation.
  2. Likes desidetailer liked this post
  3. #32
    Junior Member desidetailer's Avatar
    Jan 2018
    Chandigarh, India
    43
    So if One has to go with a combo of coatings say firstly uk is applied and then it has to be topped up with gliss... so a single coat of each or can 2 coats of each be applied?
  4. #33
    Jun 2013
    LA, CA
    8,719
    One coat of each would be fine. If you really wanted to do multiple coats then two cots UK and one of Gliss.
  5. Likes BudgetPlan1 liked this post
  6. #34
    Jan 2018
    Chandigarh, India
    43
    Coool...
    many thanks
  1. Replies: 3
    Last Post: 08-28-2018, 10:19 AM
  2. Replies: 18
    Last Post: 10-18-2016, 06:30 PM
  3. Replies: 11
    Last Post: 08-09-2016, 09:29 AM
  4. Replies: 9
    Last Post: 04-19-2016, 12:35 PM
  5. Best compound/polish combo before CQuartz UK?
    By olenderc in forum Auto Detailing 101
    Last Post: 03-22-2015, 11:07 PM
