Page 2 of 5 FirstFirst 12345 LastLast
Results 11 to 20 of 44
    Regular Member crovello's Avatar
    Feb 2011
    Massachusetts
    113
    Re: Tire Dressings PERL vs Hyper Dressing D170
    Quote Originally Posted by Goonie75 View Post
    I don't think so. Maybe in the middle to just shy of the middle of 'glossiness'. If you put on two coats it's a little more gloss. not near as glossy as Griot's Garage Black Shine Tire & Trim coating. And not as glossy as a petroleum-based product but I'd say it's definitely not satin or matte
    The tires on my dad's Jeep were done with Opti-Bond
    Sent from my SM-G935V using Autogeekonline mobile app
    That is just the amount of shine I like on my tires. What do you use to apply it? I have read threads of people using flagged tipped brushes. I would like to try that if I knew what a flagged tipped brush is
    2017 Toyota Tundra
    2013 M37S Infinity
    2007 BMW 335i convertible
    Super Member Goonie75's Avatar
    Feb 2017
    696
    Quote Originally Posted by howardm4 View Post
    Goonie, is that 1 coat or 2? Sorta looks too glossy for only one. I personally am a satin-y advocate. I like 1 coat.
    Hi howardm4... that happens to be 2 coats... honestly it was my first use with that product so wanted to see what happened with 2... it is a lot more 'muffled' with just one (1) coats... i kind of like satin'y too but 'dad' likes it shiny... lol... it held up darn well too... still rich in color... not as 'shiny' black, but still rich after most of winter...
  3. Likes Robbiek liked this post
  4. #13
    Super Member luckydawg's Avatar
    Jan 2016
    1,117
    I like perl only on the inside like a lot of folks on here- also not on tires
    My preference for tires is AMMO tire mud gel- its a bit shiney for me- but if you wipe off the excess after an hour or so its pretty nice
    Perfect for me after about 2 days-- lasts pretty good also
  5. Likes Goonie75 liked this post
  6. #14
    Feb 2017
    696
    Quote Originally Posted by crovello View Post
    I apply with some soft sponges from the dollar store. Pack of 6 or so for a dollar or 2...
    Carrand Brush & Shine Tire Dressing Applicators, tire brush, tire shine applicator
    Or
    Boar's Hair Wheel Brush
    Or
    And forgive me forum folks... Chemical Guys also has a 'Flagged Tip Brush' that technically isn't carried here that works well for tire dressings
  7. #15
    May 2017
    262
    I use the green/black Chem. Guys applicator. Lasts about a year on 3 cars.
  8. Likes Goonie75 liked this post
  9. #16
    Super Member FrankS's Avatar
    Jul 2013
    West Palm Beach, FL
    1,560
    I have PERL and Hyper Dressing on my car right now. I have PERL diluted 1:1 on my front tires and Hyper Dressing diluted 1:2 on the rear. The look is about the same for both. I like a low sheen look, not too glossy, a little more than natural.
    I've tested them before and the duration is about the same...depends on the weather. I think you're going to get about the same duration out of most water based dressings.
    Solvent based dressings will last longer but I don't like using them. I prefer to use water based.
    It doesn't take long to reapply the dressing when needed. I normally reapply tire dressing on my customer's cars every time I do a maintenance wash anyway since I normally clean and scrub the tires.
    I would give a slight edge to PERL as far as durability (but not by much), and PERL seems to be a little thicker than Hyper Dressing. Hyper Dressing a little more watery when applying but I think Hyper Dressing is more economical.
    IMO, I think either one is a good choice.
  10. Likes Goonie75, PaulMys liked this post
  11. #17
    Super Member VISITOR's Avatar
    May 2007
    9,741
    i have used/had both opti-bond and hyper dressing and since using PERL i no longer use/buy either of them anymore. PERL is one of the best water-based dressings out and will always have a spot in my detailing arsenal...
  12. Likes The Guz liked this post
  13. #18
    Super Member Pats300zx's Avatar
    Mar 2006
    Middletown, Del
    5,297
    I have had horrible luck with durability with PERL and only use it for interior dressings. I much prefer Hyperdressing at 1:1 for my tires.
    Only Z Best Detailing-Automotive Concours Detailing Services
    http://ozbdetailing.com
    https://www.facebook.com/ozbautodetailing
  14. #19
    Regular Member machz's Avatar
    Mar 2012
    NH
    175
    I used 303 for years but have moved to PERL at 1:1 and have been very happy. For me the durability is in line with other dressings I have used and I like the matte look.
  15. #20
    Jun 2013
    Montreal, Quebec
    3,996
    I have been using Opti-Bond for the last 5 years. My bottle is finally empty (or just about) As a replacement, I purchased Meguiar's All-Seasons Dressing. It's not water based, and from what I have read here it doesn't sling. Durability should be 10 times that of any water based dressing. Will be able to comment more once I have used it for a while. I like Optibond, but it simply doesn't last. I have had clients tell be it lasted about a week... that's not good ;(
  16. Likes derass liked this post
  1. Replies: 29
    Last Post: 05-26-2018, 09:13 PM
  2. D170 Hyper Dressing
    By HateSwirls in forum Products Guides
    Last Post: 12-20-2013, 11:32 PM
  3. Carpro PERL -- My Favorite Tire Dressing
    By ihaveacamaro in forum Product Reviews
    Last Post: 09-10-2013, 05:45 PM
  4. Tire Dressed with Meguiars Hyper Dressing
    By FussMan in forum Auto Detailing 101
    Last Post: 10-01-2011, 07:33 PM
  5. Meguairs D170 Hyper Dressing
    By santov in forum Product Reviews
    Last Post: 08-29-2009, 02:55 PM
