Results 1 to 10 of 10
Thread: ONR and Sio2?
    Junior Member Hella JDM's Avatar
    Aug 2014
    82
    ONR and Sio2?
    What are peoples thoughts of mixing in an LSP with ONR as a rinseless or waterless wash? I was thinking about adding Mckees Sio2 sealant to my bucket on my next wash.
    Nov 2015
    Los Angeles, California
    13,778
    Re: ONR and Sio2?
    Or you could just buy some Carpro Ech2o, since that’s basically what you’re looking for.
    Aug 2014
    82
    Re: ONR and Sio2?
    I probably will eventually, but I have ONR and McKee's 37 Sio2 on the shelf so I thought I'd ask.
    Nov 2015
    13,778
    Re: ONR and Sio2?
    Are you talking about the McKee’s SiO2 Spray on hose of product? Or the SiO2 car wash soap?
    Aug 2014
    82
    Re: ONR and Sio2?
    Spray on hose off is what I was thinking. But I have both.
    Super Member The Guz's Avatar
    Jun 2013
    LA, CA
    8,719
    Re: ONR and Sio2?
    You are referring to hydro blue or SiO2 wash from McKee's?
    You could try and see if that would work in a small area. Definitely ask Nick as it is taking hydro blue out of it's normal application process.
    Aug 2014
    82
    Re: ONR and Sio2?
    Hydro Blue but I have the wash as well
    Nov 2015
    13,778
    Re: ONR and Sio2?
    Quote Originally Posted by Hella JDM View Post
    Then you definitely don’t want to mix those 2. You’ll wind up with a bad reaction because that McKee’s product needs to be applied to clean paint and immediately rinsed off with a strong jet of water. Trying to use it as part of the rinseless wash would likely lead to a short term disaster in streaks that won’t come off very easily.
    Jan 2014
    SoCal
    1,122
    Re: ONR and Sio2?
    I haven't had good luck mixing Optimum with other lines. I get muddied results. I always use Optimum washes, sealants, waxes with each other.
  10. #10
    Super Member WillSports3's Avatar
    Jun 2016
    Toronto, ON
    1,453
    Re: ONR and Sio2?
    Leave the mixing to the chemists? Unless you are a chemist in which case you need an ingredients list and solvent percentage in each as well as the type of polymers in ONR at which point you would have to look for chemicals that react with each other and find a general solvent or neutralizer since I'm guessing whatever solvents are in the Hydro Blue have to be fast evaporating to make sure none stick on the paint and the polymers in ONR just might be neutralized by said solvent, and at the same time what carrier carries the Sio2 and how that reacts to the ONR polymers. Long story short, don't mix products that have nothing to do with each other. There's a lot of rinseless wash and wax products that actually have been engineered to lay a layer of some kind of protection on. Don't waste your money mixing products meant to do two different things from two different manufacturers. If you like ONR, you can mix in some Opti Seal with your ONR for a wash and seal product.
    2016 Mazda 3 Sports GT
    2015 Lexus IS250 F Sport
  11. Likes Jeremy1976 liked this post
  1. SiO2 and wax over?
    By mikeci in forum Ask your detailing questions!
    Last Post: 06-29-2020, 10:41 AM
  2. To use SiO2 or not
    By Phil_M in forum Blackfire Wax Products
    Last Post: 05-13-2019, 09:06 AM
  3. Have you use any SiO2 waxes, what's out there?
    Last Post: 01-10-2019, 07:23 PM
  4. Any sio2 ceramic detail spray or ceramic sio2 spray waxes?
    By Demonicus666 in forum Auto Detailing 101
    Last Post: 10-15-2018, 07:07 PM
