Re: Can I polish directly after using a Nanoskin Autoscrub with Nanoskin Glide?
Originally Posted by
SWETM
I used a 21mm longthrow polisher DA and a medium polishing foam pad. The places it did not get to I used the foam applicator that came with which also had a little cut. On the DA I primed the pad and applyied 4 small pea drops. Then worked on 2×2 feet area. I think it's depends on how much imbedded grime you have on how much you need to apply on the pad and the working area you work on. The car I was doing was really in bad shape so think that I had to use a little more than a car in good shape. You see that when you are spreading the product so you have an even hazed on the paint. Then work it to it's clears up and then wipe of. Noticed when I was over working it got a little trouble to get wiped off. Between 3-5 passes per sections then it's done. The longevity of Ultima PGP was extended quite a bit.
Thanks so much - this is very helpful. I know with Ultima a little goes a long way but I couldn't find instructions on how much to apply to a pad.
