Results 1 to 6 of 6
    Oct 2013
    141
    How to remove water spots from black Toyota paint?
    Hi all
    I have a black Toyota that has water spotting on the hood and would like to remove them.
    I tried using CarPro Spotless but it did nothing.
    Are there any other products I could try or has the water spotting etched in too far that it needs to be cut and polished?
    Any compound/polish and pad combo recommendations for black Toyota soft paint would be great!
    Super Member TTQ B4U's Avatar
    Jan 2016
    Central Ohio
    5,438
    Re: How to remove water spots from black Toyota paint?
    Quote Originally Posted by cheekyage View Post
    Hi all
    3D Eraser Gel would be the next step. If that doesn't do it then Start with a polish like Meg's Ultimate Polish/M205, etc.
    2023
  3. Thanks cheekyage thanked for this post
    Likes cheekyage liked this post
  4. #3
    Oct 2013
    141
    Quote Originally Posted by TTQ B4U View Post
    Do I need to machine polish or can I use the Megs M205 by hand application?
  5. #4
    Jan 2016
    Central Ohio
    5,438
    I would machine polish. You'll get way better results. From there if polish doesn't work, then Ultimate Compound followed by polish. I would definitely give 3D Eraser Gel a try though. Make take 2 applications but it's usually done the trick for me on hard water stains on glass.
    2023
  6. Thanks cheekyage thanked for this post
  7. #5
    Oct 2013
    141
    Thanks TTQ B4U
    If I apply 3D Eraser Gel will it strip the existing wax/sealant/coating?
  8. #6
    Jan 2016
    Central Ohio
    5,438
    Thanks TTQ B4U
    Wax / Sealant yes, coating, not likely. It's targeted at dissolving minerals. I would suggest a decent coating topper that is paired with your coating. If you have coating, just re-coat the panels where needed. Most likely it's just the horizontal areas. Works great on glass too. Scrub glass with the Gel and a magic eraser. Just make sure you rinse glass off after 1 minute. Do not let it sit on glass more than 1 minute. On paint, again, it may take 1-2 applications.
    2023
  1. Replies: 20
    Last Post: 09-20-2017, 04:24 PM
  2. Jet Black (BMW) paint, can't get out etching (water spots?)
    By mcfreid in forum Ask your detailing questions!
    Last Post: 05-08-2017, 09:24 PM
  3. 1955 Chevy Bel Air with a $15,000.00 Custom Paint Job - How to remove water spots
    By Mike Phillips in forum PICTURES: Wednesday Night Detailing Classes
    Last Post: 07-06-2016, 02:52 PM
  4. Black paint and water spots
    By red98snake in forum Ask your detailing questions!
    Last Post: 09-11-2011, 01:03 PM
  5. What's the best way to remove hard water spots from paint
    By arkus in forum Auto Detailing 101
    Last Post: 11-20-2010, 09:41 PM
