Page 1 of 5 12345 LastLast
Results 1 to 10 of 45
    Aug 2011
    Far north Phoenix, AZ
    128
    Lake Country pad failure
    I've been using Lake Country pads since 2012. I find them to be very durable and they work great. I've mainly been using the orange and green pads. I just bought a pack of 6 and one that I got was the most aggressive (yellow) pad. The 2008 VW Passat that I had this past weekend had extremely hard paint, so I gave it a try. It worked great with M105 and my Porter Cable set to 5.5. I rarely go over 5, but this paint needed some RPM.
    I noticed it feeling a tad warm after an hour or so. Then, all of a sudden, the pad flew off the backing plate. I found that the black portion of the pad separated from the rest of the pad. My guess is that the glue warmed up and just let loose.
    Has anyone else had this issue? Can I just glue it back, or is there any type of warranty? This is literally the first time I used it and for about 2 hours. Like mentioned above, I still have orange pads from 5+ years ago still going strong, so I was very surprised to see this one come apart.
    Aug 2010
    New Jersey
    15,189
    Re: Lake Country pad failure
    You used the same pad for an hour straight? Is that what you do with the orange ones?
  3. Likes custmsprty liked this post
  4. #3
    SELF BANNED
    Sep 2017
    570
    I’ve had all 6 of my LC flat yellow 5.5” pads delaminate on me and switched to BnS flat yellow 5.5” without a single pad failure.
  5. #4
    Super Member Route246's Avatar
    Mar 2017
    NorCal - San Mateo County
    1,037
    What is the condition of the foam surface? I've had them overheat and shred chunks but never separate. If the surface is pristine and still intact I would say this may be a defective pad.
  6. #5
    Mar 2017
    Southeastern PA
    2,480
    If they were being used for more than an hour I bet the pads got too hot and the glue just failed. That seems like overuse, especially at higher RPMs like you mentioned. Heat is the #1 enemy of pads.
    Bruno Soares
  7. Likes custmsprty liked this post
  8. #6
    Jul 2017
    RI
    531
    no glue in the world would stand up to those temperatures.
  9. #7
    Aug 2013
    St Louis metro (Illinois)
    5,819
    The heat most certainly killed the pad. The trick is to rotate out your pads every couple of sections.
    I have had one white LC Flat Pad separate on me and it was clearly a case of being too hot and the glue let go.
  10. #8
    Aug 2011
    128
    I've never had the need to run my Porter Cable that high before. I couldn't believe how loud it got after going past a setting of 5. I normally swap out the orange ones after a few panels, but I only have the one yellow and it was doing such a great job of the swirls, that I kept at it.
    I already received a PM from a rep at Lake Country offering to replace it for free. Talk about going above and beyond.
  11. #9
    Jul 2015
    165
    I have had a couple of yellow ccs pads seperate recently. I planned on asking about them next time I order. I have about a dozen yellow, and use a new one for every panel, so heat wasn’t the issue with mine.
  12. #10
    Dec 2014
    Boonsboro, Md
    2,724
    I’ve destroyed a few of the yellow LC Flat pads with my Deutto running them a top speed and over using them when I first started machine polishing.
    Mostly sunken centers and one started to delaminate. Definitely user error on my part being inexperienced and pushing them to far, although it does seem to have only happened to the yellow ones.
    My white and orange ones have held up well. I really like the orange ones, they are great for one steps with an AIO.
    ____________
  1. Replies: 28
    Last Post: 02-26-2022, 08:11 AM
  2. Lake Country CCS foam pad failure
    By 3Crowns in forum Wool & Foam Buffing Pads
    Last Post: 01-16-2018, 01:38 PM
  3. Lake Country, what did you do?
    By parttimer in forum Wool & Foam Buffing Pads
    Last Post: 06-21-2016, 11:22 AM
  4. lake country or ?
    By chachi94 in forum Auto Detailing 101
    Last Post: 02-11-2015, 11:26 PM
  5. Lake Country Pad Failure? or User error?
    By Maxima Mom in forum Ask your detailing questions!
    Last Post: 11-08-2010, 07:21 PM
