Page 1 of 3 123 LastLast
Results 1 to 10 of 26
    Jul 2016
    3,328
    Best products and techniques for removing road salts?
    Obviously we're in the season of brutal road salts on the highway and our cars get absolutely hammered. I saw 1 yesterday that was totally caked in white. I would post the picture but Its got the persons plate in the picture. I stay on top of mine but this winter has been kicking my but despite my best efforts.
    Anybody know any great products or techniques for keeping the road salts at bay and stopping them from destroying our lsp's
    Its been so cold I haven't been able to do my weekly wash like last year which was mild. Some weeks the laser wash is the only option. If the car is covered in dirty road salts is it better to use the laser wash or leave the salts on there and wait until you can do a proper wash?
    Dec 2017
    Re: Best products and techniques for removing road salts?
    Quote Originally Posted by fightnews View Post
    Here in Colorado they use magnesium chloride on the roads. This stuff wreaks havoc on cvehicles paint and chassis. I found Valugard.com and they have a line of products that deal with road salts. So far the trailer truck wash has been great.
    I did just yesterday have to use a touch less wash. After reading the menu, I’m pretty confident if you don’t get the top of the line wash, your LSP’s should be ok and the car clean enough till you can get to it properly. Hope that helps.....
    Jul 2016
    3,328
    Quote Originally Posted by Washmitt View Post
    Why does the top of the line washes have worse chemicals then the low end wash? I know the low end wash where I am doesn't include the drying or the spot free rinse
    Jul 2013
    Apex, NC
    1,283
    I only use the basic touchless wash when I need to. Which is usually a foam bath, high pressure soap, high pressure rinse, low pressure rinse, then pass through the air blower. I don't want any of the spray LSP that they use on the higher choices. Just want the road salt cleaned off as best as it can like you said. Then do a proper wash when the conditions a re right.
  5. Likes Hammer77 liked this post
  6. #5
    Aug 2013
    St Louis metro (Illinois)
    5,809
    I simply run my vehicle through a touchless wash whenever the weather gets above freezing. There are a few places around me with the underbody spray rigs which is nice in getting the salt off the underbody and out of the wheel wells. It isn't perfect, but it removes the majority of the salt and keeps the car clean enough to get me through until Spring when I can do a proper hand wash. The whole reason I use a highly durable LSP or coating is to stand up to this type of environment.
  7. #6
    Super Member Dmb5450's Avatar
    Aug 2014
    Allentown PA
    555
    Look into the hydroshot. Depending on how often you go to spray washes this will pay for itself in no time. I got a refurbished unit with a battery and all the tools for 80 dollars. I spend 3-5 at a spray wash per visit. In one winter I will break even. I have used the soap dispenser and even ran rinseless solution through the product, with great results.
  8. Likes Frank70 liked this post
  9. #7
    Jul 2016
    3,328
    Quote Originally Posted by DBAILEY View Post
    The one I go to has a "pre-soak" not a foam bath. The pre soak is the acid, that's what strips the lsp then they do a 2nd spray to neutralize the acid. Then the high pressure wash. I've never seen one that had an actual foam bath that would be nice though. Maybe I'll have to start checking the other towns to see if they have a better 1 like that.
  10. #8
    Jul 2016
    3,328
    If the temperature is above freezing even by 1 degree I do a normal 2 bucket wash with the pressure washer. The exact same thing I do in summer. I do it every weekend. Last year I only missed 1 weekend the whole winter. Last year was more mild though this is shaping up to be the coldest winter in a while.
  11. #9
    Jul 2016
    3,328
    Quote Originally Posted by Dmb5450 View Post
    It has to be above freezing to use that but it is nice. What do you do about foam with that thing? I might buy one to add to the arsenal. It's not much money at least but if its warm enough for that It's warm enough for a pressure washer.
  12. #10
    Aug 2013
    5,809
    You're a braver man than I. I find washing even in the upper 40's to be rather miserable. My hands just get too cold when wet and I lose feeling in several fingers.
    A pressure washer would be a big help I'm sure and would probably lower my threshold of temperatures. Going at it with the hose is a not starter in the cooler/cold temps.
  1. Removing road paint
    By barryjowens in forum Auto Detailing 101
    Last Post: 07-20-2017, 03:00 AM
  2. Removing road paint
    By ShineRight in forum Ask your detailing questions!
    Last Post: 12-01-2013, 01:30 PM
  3. Removing Road Paint??
    By Eurocougar in forum Auto Detailing 101
    Last Post: 10-06-2008, 10:44 PM
  4. Removing Road Paint
    By Racin10s in forum Auto Detailing 101
    Last Post: 09-08-2008, 07:57 AM
  5. Products & Techniques - Clearbra owners
    By MadOzodi in forum Auto Detailing 101
    Last Post: 06-01-2007, 03:30 PM
