Results 1 to 7 of 7
    Oct 2016
    GG6 backing plate
    I am getting a GG6 for Christmas. I currently have PC with a 3.5" & 5" lake country baking plate. I am thinking of using just the 3.5" on the PC and the 5" on the new GG6. So, my question is. Would a weekend warrior notice difference between the LC 5" backing plate and the GG vented backing plate? Is it worth upgrading to the GG vented plate?
    Thanks for your comments.
    Super Member JHL88's Avatar
    Mar 2013
    1,137
    Re: GG6 backing plate
    No. More than likely you won't notice a difference. At least I didn't. Its supposed to dissipate heat and if you don't polish very often and switch out pads continuously it won't hurt to stick with your LC backing plates.
    Super Member Belair's Avatar
    Jan 2011
    Denver foothills
    734
    ^^ Agreed.
    Super Member JustJesus's Avatar
    Oct 2014
    Orange & LA Counties
    1,294
    Can't say I felt a difference between backing plates. My GG6 does wear the vented one sometimes.
    Bigger difference is felt using the newer thin pads. At least in my experience
    Super Member brettS4's Avatar
    Jan 2015
    Wisconsin
    649
    Yes. You will almost certainly destroy your pads if you apply moderate to high pressure with the LC backing plate. It happened to me consistently until I bought the vented plate. Then the problem disappeared immediately.
    Super Member Cruzscarwash's Avatar
    Oct 2015
    Desert of California
    2,425
    ive only used the stock 6 inch and then the 5 inch vented. ive never had overheating issues with the pads. I also switch out on every panel but with panels that need a little more love they never get hot.
    Super Member mwoywod's Avatar
    Apr 2016
    881
    I personally can tell a massive difference between the Griot's 5" vented backing plate and the 5" Buff & Shine & LC backing plates. I've tried all 3 and IMO the griot's 5" BP keeps pads 5-10% cooler. No matter which BP you use make sure you are rotating pads after every 1-2 panels to allow them to cool and used compressed air to blow out both foam and microfiber after every pass.
    A word of caution, if you are using closed cell foam pads don't use compressed air as it will destroy the cell structure of the foam.
  1. Replies: 25
    Last Post: 10-07-2021, 02:58 PM
  2. Replies: 19
    Last Post: 05-31-2020, 02:42 AM
  3. Replies: 1
    Last Post: 09-25-2018, 11:57 AM
  4. Replies: 0
    Last Post: 09-02-2017, 08:14 PM
  5. Griots 6" backing plate VS. Lake Country's backing plate
    By ryanmcg1 in forum Product Reviews
    Last Post: 09-29-2011, 11:29 PM
