Results 11 to 20 of 22
    Super Member FrankS's Avatar
    Jul 2013
    West Palm Beach, FL
    1,560
    Re: Question for the Pro's, RE: Inner wheel cleaning/glue removal...?
    I’ve used 3M Adhesive Remover for glue residue and though it was pretty good I actually found Stoners Xenit to work better in my experience.
  2. Likes Inthedeck liked this post
  3. #12
    Super Member LEDetailing's Avatar
    Jan 2016
    Wisconsin
    1,729
    All good advice. Also adding heat from a heat gun or blow dryer helps soften up the adhesive. Still need a good adhesive remover after softening the adhesive.
    Use caution with heat guns. Especially around rubber, do not let the wheel get too hot. Just warm enough to start making removal easier. Never use flammable liquids around the heat gun.
  4. Likes Inthedeck liked this post
  5. #13
    Junior Member Inthedeck's Avatar
    Nov 2017
    N. E. Florida
    47
    I don't really need a ton of product for this, so, I'll get the smallest size I can find. Thanks for all the tips and products. I'll get them all cleaned up, and hopefully, they'll find a new home, soon.
  6. #14
    Super Member Paul A.'s Avatar
    Dec 2007
    Tampa Florida
    5,274
    Another great tip, LED, I forgot heat helps too. Just like debadging, a heat gun or blow dryer used JUDICIOUSLY helps soften it up and make it more pliable.
    I wish posts like these could be summarized and stickied with the consensus points bulleted. For example...
    Wheel weight residue removal:
    1. heat it up carefully with a heat gun or blow dryer
    2. Using nitrile gloves, take an old towel or paper towel and soak it with adhesive remover (3M, Xenit, Stoners Tar Remover, Acetone or your favorite) and lay it on the residue. Don't let it dry! Keep it moist and wet. If the current balancing weight is close bg, avoid getting it wet with remover product.
    3. Take a plastic razor blade, old terry towel, Q-tip (soaked in adhesive remover from #2), old tooth brush (youngest child's from the house works best as you can simply blame the older sibling) or your favorite removal tool and carefully work the residue until it's gone. May take several applications.
    4. CLEAN wheel thoroughly to remove any residual adhesive or removal product.
    Or...
    5. Just grab an eraser wheel and substitute for 1 through 4. (Sorry, Zack, just playin' witcha!).
    Sorry if I missed some tips here or there but you get the jist.
  7. Likes SWETM, Inthedeck, LEDetailing liked this post
  8. #15
    Super Member zmcgovern45's Avatar
    Sep 2012
    St. Louis, MO
    3,443
    Honestly... I've found eraser wheels to be the absolute quickest and easiest way to completely remove this type of residue. I used to soak with all sorts of solvents... but it makes a mess and still takes a while. The eraser wheel is quick, easy, and not messy.
    Retired Professional Detailer
  9. Likes SWETM, Inthedeck liked this post
  10. #16
    Super Member Audios S6's Avatar
    Oct 2011
    Shoreview, MN
    1,634
    Quote Originally Posted by zmcgovern45 View Post
    Eraser wheels are rarely talked about here and highly underrated.
    Use caution and go slow and it will still be way faster and less elbow grease than chemical removal, even if you have a little polishing to do afterward
    Static & Mobile detailing in Minneapolis & St. Paul. http://www.detailedcreationsmpls.com/
  11. Likes Inthedeck liked this post
  12. #17
    Jan 2016
    Wisconsin
    1,729
    I had never seen an eraser wheel till I just looked it up. That looks quick and easy.
    Do you stay away from using it on painted body panels other than inner barrels of wheels? For wheel weight clean up it does look like a great tool.
  13. #18
    Nov 2017
    N. E. Florida
    47
    ^^Agreed, I'd never heard of them either. Seems like a useful tool, and will help keep rims clean after wheel weight changes.
  14. #19
    Sep 2012
    St. Louis, MO
    3,443
    Quote Originally Posted by LEDetailing View Post
    They can be used on painted body panels, but the instructions state to NOT use them on plastic panels like bumpers. The eraser wheel can generate quite a bit of heat, so it isn't too big of a deal to use one on the barrel of a wheel, but you must use caution and common sense when using one on the exterior of a vehicle. When used properly, they make quick work of removing adhesive residue, specifically residue from 3M type double sided tape that is often used to attach aftermarket pieces or badges.
  15. #20
    Aug 2015
    Andover, MN
    1,727
    Agreed on the eraser wheels. They’ve worked pretty well when I’ve used them, be sure to use common sense.
    I’ll have to time it next time I do tires - To be honest, I don’t remember a time where I’ve spent more than a few minutes a wheel cleaning up all the weight residue with the approach I mentioned before.
  1. 23 Year old car badge removal - Stubborn Glue
    By BA540i in forum Auto Detailing 101
    Last Post: 08-17-2019, 04:26 PM
  2. Replies: 0
    Last Post: 03-25-2017, 12:36 AM
  3. Wheel weight glue removal
    By t5620 in forum Auto Detailing 101
    Last Post: 09-24-2013, 06:10 PM
  4. Body shop Glue removal
    By Dave Medvic in forum Auto Detailing 101
    Last Post: 05-07-2013, 05:06 PM
  5. Tape Glue removal
    By Buckskincolt in forum Ask your detailing questions!
    Last Post: 09-23-2009, 11:07 AM
