baked on bmw brake dust
is there a method/product that is capable of completely removing baked on bmw brake dust on a car that has not had its wheels cleaned properly in over a year
Re: baked on bmw brake dust
P21s Gel with a good brush or even bug scrub sponge. If your wheels are coated, you may try Meguiar's Wheel Brightener, which will without a doubt get rid of any of that junk, but be careful because it is powerful stuff and will damage bare aluminum wheels. Most BMW wheels are coated, but just double check. P21s gel will be the safest, but may not be strong enough. I have never tried P21s so I can't comment on its cleaning ability, but I have heard that it is perhaps the best wheel cleaner from a lot of people.
You may also try some clay. Look into a medium to aggressive clay, than just polish the wheel up afterwards and you should get some pretty impressive results.
All you need is Poorboy’s World Spray and Rinse Wheel Cleaner and the EZ Brush. After you have them cleaned, apply Poorboy’s World Wheel Sealant and the wheels will be clean and protected!
_____________________________________
"Dogs in cars again. Going away. Going away fast" - P.D. Eastman, Go, Dog. Go!
I have used Poorboy's Spray and Rinse on chrome wheels with luck, but it is so acidic it east up through a sprayer.
Your BEST solution will be P21S GEL wheel cleaner. Spray it on, let it sit for 2 houts, then scrub your wheels with a wheel brush (EZ brush, or OXO). You will be amazed by this wheel cleaner. It's expensive, but is well worth it.
SELF BANNED
See -http://www.detailingbliss.com/forum/f35/wheel-cleaners-1201.html
Thanks for the good info TOGWT.....I still want your book....
Wheel Cleaners:
It is important to keep wheel surfaces clean, as well as improving the overall look of the vehicle leaving them dirty can have many adverse effects; the black powder coating on the surface of your wheel has four components; a static friction charge (caused by the pads contact with the rotors) that attracts dirt, road tar and other contaminants kicked up by both your vehicle and others. Friction heats the pads and callipers to extremely high temperatures, and causes tiny particles of hot metal to wear off and sent flying in different directions.
Many of these hot metal particles land on your rim and literally fuse themselves to the surface. Finally there is brake pad adhesive, modern brake pads are complex compounds of metals, synthetic materials and adhesives (the binder system) which is designed to wear away under friction like the rest of the pad. The adhesives used in brake pads can be very difficult to remove and they are also corrosive and will etch the wheel surface, the metal particles from the pads and rotors will become a conduit for rust compromising the paint surface of your wheel
Wheel cleaning is not that difficult, especially if you use the correct tools, they have to work safely but effectively. Wheel cleaners that contain acid are the most dangerous, there are wheel acids that are safe if used with care and the directions are followed precisely. Accidents and expensive wheel replacements can always be avoided if you do some research and are smart about your choices. Always check the products MSDS and its pH value before you use it. It is always preferable that you use a 100% acid-free product with a pH of 7.5 – 8.0
Cleaning Clear Coated Wheels:
•Ensure wheels and rotors are cool before applying cold water as this may cause them to warp. Hose off as much initial grime as you can. Rinse up into the wheel well to wash away road kill, mud and other debris.
•Use detailing clay to remove any embedded contaminants
•Use a solvent based cleaner to remove any road tar
•Apply a solution of P21S Total Auto Wash to wheel-wells and tyres, and let soak in, agitate with a long-handled boars haired brush before rinsing
•Spray P21S Wheel Cleaner (Gel or Liquid) this cleaner is 100% acid-free and will not damage any type of wheel finish. (Gel for badly soiled and regular for normal soil) onto wheel rims and lat soak in (for badly soiled surfaces us P21S-Red (422)
•Before finally removing cleaner, agitate with a soft brush and then rinse off (See Wheel Brushes)
•Rinse wheel surface thoroughly with clean water (to avoid splashing paint surface rise by pouring a bucket of water over each wheel from the top down
•Remove any surface imperfections with a suitable clear coat polish (Dependant upon extent of damage)
•Dry wheels with a towel, apply a polymer sealant (ZoopSeal) to the surface of the wheels, it will protect the finish from brake dust and the elements and also make them easier to keep clean.
•Wax has a low melting point and will not withstand the sustained temperature
Polished Aluminium Lips -they can be either a clear coated, anodized, or bare polished aluminium in which case different types of polishes are needed for each. Bare (uncoated) aluminium, using a metal polish will turn the cloth black. Use Mothers Mag and Aluminium Polish and Mother’s Powerball –
Note - Bare aluminium will oxidise (turn a yellowish colour) if a highly acidic or alkaline product is used.
Menzerna Gel 7.5 Wheel & Tire Cleaner- pH-Neutral (7.5) a detergent-based cleaner with surfactants, wetting agents and emulsifiers (for cutting road oils) which quickly cleans both tires and wheels yet is as gentle to the surface as drinking water! This cleaner contains no acids, petroleum solvents, butyl or butyl ethers of any kind, neither acidic or alkaline it cleans tires and all types of wheels including billet aluminium, plated, polished, anodized, powder coat, painted and clear coated. - Classic Motoring Accessories - Car Buffers, Car Waxes, Car Polishes, Auto Detailing Supplies, Car Covers, Car Accessories
Alternative products –
P21S Gel or Liquid Wheel Surface Cleaner (Green) originally developed in 1976 by a German chemist, a water-based, (non-acid) detergent that provides terrific cleaning and guarantees not to damage painted, clear-coated, or anodized wheels - Performance Motorcare Products Ltd P21S
P21-S Wheel Cleaner (Felgen-Reiniger) Power Gel (Red)– manufacturers approved way to remove corrosive brake dust and road grime from alloy wheels. Safe, pH controlled, formula is guaranteed not to harm any type of road wheel, braking system or other automotive surface, works safely and effectively on every type of wheel and coating, removes brake pad adhesive and sequestered metal brake dust safely - Classic car, kit car and motorcycle restoration - Frost Auto Restoration Techniques Or Die Seite kann nicht aufgerufen werden
Wheel cleaners that are formulated with Hydrofluoric acid; that is a solution of hydrogen fluoride in water, it is corrosive, meaning it will have a detrimental (and sometimes unrecoverable effect on surfaces it’s applied too) and it is also highly poisonous. The application instructions usually state- ‘apply, but do not allow product to remain on the surface for more than 30 seconds before removal with a strong stream of water’.
Skin contact with concentrated hydrofluoric acid or inhalation of its vapour has caused many serious injuries, even death. Concentrated solutions of hydrofluoric acid pass quickly through the skin and cause deep, painful burns. Dilute solutions also penetrate the skin, but it does not give the immediate burning sensation caused by the concentrated form of the acid, a user may tend to be less aware of the contact with the acid.
There are specific ordinance to enforce Hydrofluoric acid hazard spill control / exposure and treatment methods and specific materials, most of which are just not going to be in the enthusiast or even mobile detailer's toolkit, non-compliance can result in heavy penalties.
It also has the unique ability to dissolve almost all inorganic oxides. In the human body, hydrofluoric acid reacts with calcium and damages nerves, bone, and several organs including the heart and kidneys - Hydrofluoric acid - Wikipedia, the free encyclopedia
Critics say the lack of knowledge about chemicals exposes a system where environmental regulators largely rely on companies that profit from industrial chemicals to sound alarms about their safety. Questions about potential effects on human health and the environment often aren't raised until years after a chemical is introduced to the marketplace.
Notes –a) Acid is highly corrosive; the skull and crossbones warning on an acid label is there for a reason; acids will etch or erode anything in its path, they are also very effective in dissolving metals and etching glass.
b) Even a pH 5.0 acid with a dilution rate of 4:1 (as recommended by Meguiar's for their Wheel Brightener) results in a pH 4.5 solution. The dilution of an acid doesn’t make it safer as the addition of a molecule of water to a chemical compound, without forming any other products is known as hydration (i.e. dilution causes the pH to decrease) But since pH is not a very good indicator of the strength of the acid in every system, this approach won't always produce the desired results.
c) A wheel cleaner formulated with Oxalic acid is a safer yet still very effective cleaning chemical. It will do a better job than alkaline cleaners, but is nowhere near as harmful to the vehicle or yourself. Oxalic acid is a relatively strong "weak acid" Oxalic acid exhibits many of the reactions characteristic of other carboxylic acids, it’s a relatively strong organic acid, being about 10,000 times stronger than acetic acid (Vinegar pH 2).
This acid still needs to be handled with care and diluted correctly, but it’s safer than Hydrofluoric acid yet a very effective alternative.
d) Always check the products MSDS and its pH value before you use it. It is always preferable that you use a 100% acid-free product with a pH of 7.5 – 8.0
By Monster42 in forum Auto Detailing 101
Last Post: 06-14-2020, 07:03 PM
By gujunilesh in forum Ask your detailing questions!
Last Post: 07-14-2014, 01:00 PM
By ecoautospa in forum Ask your detailing questions!
Last Post: 02-21-2014, 11:13 PM
By s500 in forum Auto Detailing 101
Last Post: 09-18-2012, 07:07 PM
By vleong1 in forum Ask your detailing questions!
Last Post: 08-06-2010, 09:45 PM
