Page 1 of 2 12 LastLast
Results 1 to 10 of 20
    Jul 2017
    310
    Windshield 1... me 0
    So based on some threads here, I tried polishing out wiper scratches and swirls from my glass. I used GG Perfecting Cream on a light polishing pad (same as what I used to remove some clear bra installer swirls from my hood... worked great for that). It did almost nothing on the windshield, and I worked it pretty hard.
    So the next step up from a product standpoint is GG Fast Correcting Cream. Or I could go with a more aggressive cutting pad. Any opinions here? What should I try next? I don't want to destroy my $1000 windshield, but it's pretty shot out.
    On that note, does exterior glass have a coating on it? If so what is it? I've found some vague info online (UV coating?), but googling windshield+coating yields a lot of unrelated topics... like windshield coatings. Windshield 1... me 0
    Appreciate any help here.
    Super Member DogRescuer's Avatar
    Apr 2013
    Hurt, Va
    1,801
    Re: Windshield 1... me 0
    Test
    Steve
    -The Titanic Was Built By Professionals But The Ark By Amateurs-
    "Boanerges"
    Mar 2017
    Southeastern PA
    2,482
    Glass is much harder than paint. Use your strongest compound and pad and even that might not be enough. They sell special products to polish glass for that reason.
    Bruno Soares
    Super Member LEDetailing's Avatar
    Jan 2016
    Wisconsin
    1,729
    Carpro ceriglass and Carpro's glass polishing pads worked well for me.
    I also used a rotary polisher.
    I don't believe that you will have great sucesss with paint polishes against wiper trails/scratches.
    Glass polishing is a lot of physical work with ceriglass. It makes paint polishing feel like a breeze.
  5. Likes kevincwelch, DaveT435, Rsurfer liked this post
  6. #5
    Jan 2016
    Wisconsin
    1,729
    And if you go the ceriglass route. Start on the passenger side as a test spot. That way if you screw up you will not have to look through your mistake every time you drive
  7. Likes Rsurfer liked this post
  8. #6
    Super Member Angus's Avatar
    Jun 2012
    1,583
    Ugh, glass polishing is the worst. It’s messy, frustrating to get right, and easy to install pig tail swirls. My $.02 - avoid it.
  9. #7
    Aug 2015
    263
    Quote Originally Posted by Angus View Post
    I've not had much success polishing glass either. Aside from cleaning the glass and getting all the water spots removed I've not been able to touch scratches. I have a GG6 and carpro glass pads and Ceriglass and after 30 mins of buffing the same spot on the passenger side glass (2015 Merc. E350) there was zero difference between it and the unpolished side. Maybe it's more effective with a rotary but I'm giving up on trying to remove scratches.
  10. #8
    Super Member FUNX650's Avatar
    Dec 2010
    Ohio, USA
    21,057
  11. #9
    Super Member kevincwelch's Avatar
    May 2013
    Oak Park, IL (Chicagoland)
    2,686
    No luck either polishing glass with regular pads and compounds. I basically use the firmest pad I have and the most aggressive compound (Menz FG400) just to get off the film and bonded material so I can create a nice substrate for applying coatings to the glass. I have used Ceriglass and glass pads in the past, and it not only is a huge mess with sling everywhere but also a lot of effort.
    Perfection is attained by slow degrees; it requires the hand of time. (Voltaire)
    2013 TESLA MODEL S | Gyeon Syncro | Gyeon Cancoat
  12. #10
    Jul 2011
    Weaverville, Ca
    225
    I've had success with Ceriglass and Carpro rayon 3 inch pad.
  1. Max cut on windshield
    By Mgavin1985 in forum Auto Detailing 101
    Last Post: 03-25-2020, 04:14 PM
  2. What's this on my windshield?
    By aquarian in forum Auto Detailing 101
    Last Post: 02-16-2017, 01:41 PM
  3. NEW windshield, now what?
    By eckmo99 in forum Ask your detailing questions!
    Last Post: 06-14-2015, 11:00 AM
  4. windshield fog
    By jonn127 in forum Ask your detailing questions!
    Last Post: 08-19-2014, 08:43 PM
  5. Windshield
    By atcjeff in forum Auto Detailing 101
    Last Post: 07-04-2009, 10:35 AM
