[Beginner] Looking for entry DA polisher to fix paint chip
Since my birthday is coming up, I would like to invest in an entry DA polisher for applying sealant and wax to my '17 WRX as well as fixing the paint chip that I have been trying to repair. I watched AutoGeek's YouTube video about selecting a DA polisher and saw that there were some that use small pads for very fine detail work and large pads to cover large areas. Can anyone suggest a good inbetween as an entry level tool?
For reference on the repair that I have worked on, you can find pictures here: https://imgur.com/a/UuSzt
As a quick background, the spot started to rust. I purchased a Subaru paint correction pen, used the ceramic nub to remove the rust, filled in the hole with paint, and wet sanded with 2500 grit sandpaper. It seems that I may need to fill the hole in a little more before applying the clear coat, but the end goal would be to polish and buff out the area to a finish similar to the rest of the car. Any other comments or suggestions on the matter are appreciated.
Re: [Beginner] Looking for entry DA polisher to fix paint chip
Welp... That was easy. Thank you for the suggestion! It seems this one is the most versatile and won't require me to purchase multiple DA polishers for different applications. I will just add a 3" backing plate and the appropriate pads for easy swap out.
[EDIT]
Should I consider a dual action random orbital versus a random orbital... if those two things are even different?
Reason: Additional question
Would the fitting be incorrect if I use a 5.5" pad on the 6" backing plate? Or should I always shoot to have at least equal to the size of the backing plate when selecting a pad?
the GG6 comes stock with a 6" backing plate in which you can use 6.5" pads (6 inches of velcro). so using 5.5" pads (5 inches of velcro) with the 6"backing plate would be too small. while the GG6 has lots of torque and can spin 6.5" pads, using 5.5" pads would help maximize pad rotation. you can always use 6.5" pads on large flat panels if you like. most PC-style DA's have a problem with rotating larger pads but as mentioned the GG6 can spin them. honestly, since i got my GG6 many years ago the first thing i did was take off the backing plate and put a 5" on and haven't looked back. if i were to do it all over again i would get all those items above and the only thing you can experiment with is different pads...
By 2black1s in forum How to Articles
Last Post: 04-15-2022, 08:52 AM
By tfrost92 in forum RUPES BigFoot Oribital Polishers
Last Post: 01-27-2018, 03:27 PM
By LAKings22 in forum Auto Detailing Tools and Accessories
Last Post: 10-16-2015, 08:36 PM
By Stegs in forum Auto Detailing 101
Last Post: 03-09-2015, 09:47 AM
By Dtx oreo in forum Auto Detailing Tools and Accessories
Last Post: 06-26-2011, 07:22 PM
