Removing polishing compound?
What's the best way to remove polishing compound before sealing???
Re: Removing polishing compound?
IPA wipedown with MF cloth.
Good ole clean MF towel. If you're getting stuck on small patches you're using too much or overextending your pad saturation. In that case change out to a fresh pad with less product and run over the patches again.
I also love Car Pro Eraser for dealing with stubborn residue.
If it's a sealant I would say IPA wipe down. If it's actually a coating I will usually use the manufacturer of the coating brand paint cleaner.
2015 F-150 Crew Cab Lariat
2016 Chevrolet Camaro 2SS
I'm not a pro by all means, but I found using the correct MF towel and Mike Philips 10% IPA dilution works for me. When I say the correct MF towel, I mean some MF towels don't wipe well, they smear. I haven't tried ALL the MF towels, but Meguiars MF towel works well and fits the bill. This towel also doesnt scratch soft paint like some has for me. However, it can leave very fine lint on the surface.
Are you going from a polishing/compound straight to sealing?
If so, what polishing compound?
What are you using to "seal" with?
Little details can make a huge difference.
And just to note so there's no confusion...
The ONLY reason I wrote the below article was because a YEAR before I finally broke down and wrote it there were a few super smart experts telling everyone on this forum to wipe their paint down with IPA.
Except for one thing - they never included ANY EXTRA INFORMATION. Just a one-liner like this,
"use IPA to wipe the paint"
I know from first hand experience that if too strong a solution of IPA is accidently left on the surface it can harm the paint.
So I asked for someone else to make up for their expertise (or lack thereof), and write an article. NO ONE took on the responsibility for one year. So finally, in an effort to provide REAL helpful and accurate information I wrote the article. It taught me that a lot of people like to pretend to be an expert but when it comes to actually doing a little research and then typing out something they can attach their name to - crickets.
Note I my self don't use IPA. Never have, rarely ever do unless it's all that's around and NOW DAYS there are so many real options on the AG store I don't think I'll ever use IPA. Didn't before I wrote the article, never did after I wrote the article. I wrote the article to make-up for other people's lack of helpful information and their willy-nilly manner of just slinging their stupid advice all over the blogosphere.
Below the article.
Note the word important is RED and BOLD and then you learn why from y research for writing the article.
And then for this post, I'm going to make another pertinent portion bold red. In the second paragraph, the first sentence that is now in red font, that's me being very very nice by not stating the actual reason for writing the article and naming names.
Originally Posted by Mike Philips DATE: 12-17-2010, 01:22 PM
How to Mix IPA for Inspecting Correction Results
WARNING
Do not chemically strip FRESH PAINT. Fresh paint has not fully cross-linked, dried and hardened. Introducing any type of solvent to the surface and allowing it to dwell could have a negative effect on the paint.
Note: The below article is NOT an official recommendation by Mike Phillips or Autogeek. It is an attempt to clear up any confusion on the topic of chemically stripping paint with the common products used for this procedure as discussed on detailing discussion forums. If you choose to chemically strip your car's paint, or your customer's car paint, all the risk is yours. Anytime you use a new product or procedure, it's a great idea to first test in an inconspicuous area and check the results before moving forward.
Common, easily found options for Isopropyl Alcohol also called IPA
Anyone wanting to use IPA I recommend reading the entire article.
Me?
I tend to use either Wolfgang Perfekt Paint Prep or BLACKFIRE Crystal Coat Paint Prep, or CarPro Erasure, or GYEON Prep.
Heck I would drive to Lowe's and buy de-odorized Mineral Spirits before I used straight IPA. Good enough for the chemists at Meguiar's, good enough for me.
thanks for clearing it up Mike. Now, you just added more stuff to my shopping list...=p
@mike p, have you used griots paint prep? So far I've gotten pretty good results with it.
I use Ultimate compound and Ultimate polish. Lately I've been sealing with the DG 111/601 combo.
By Jazee in forum Hot topics & Frequently Asked Questions
Last Post: 01-15-2015, 10:19 PM
By bill buxton in forum Products Guides
Last Post: 12-07-2014, 01:12 AM
By Plan b Detail in forum Auto Detailing 101
Last Post: 07-08-2011, 10:32 PM
By TurboToys in forum Auto Detailing 101
Last Post: 10-12-2009, 08:46 PM
By Justin in forum Auto Detailing 101
Last Post: 07-19-2008, 07:30 AM
