09-02-2017, 04:17 AM
#111
Re: HD speed vs Megs D166
Originally Posted by
Cruzscarwash
Well it's hard to say and like I said above it really depends on what I'm doing
I was planning on using d166 all day for all my quick jobs but I really feel like it needs to be worked more to really take advantage of all it's benefits. It has amore refined feel to it I guess. Sounds weird but when I use it it might make more sense.
Speed is just that it's quick and can blast through the job very quickly for the results your customer is paying for in the time u need it done
So for quick work
Speed
D166
151
Taking your time and working it all in
D166
Speed
151
Sent from my Pixel using Tapatalk
ever use menzerna cut gloss and wax?
09-02-2017, 08:43 AM
#112
fightnews
That's one of my favourites right now.
Compared to speed it cuts more and I find it has a longer working time. It can be worked almost indefinitely and you can do a pretty big area at once if you want because it won't dry behind you.
Speed has an easier wipe off and can be used in the sun. Menzerna says not to use 3 in 1 on a hot surface so I haven't tried it.
Speed is my choice for cars that are already in excellent shape. For everything else I use menzerna. More cut means fewer passes to get the results I'm after.
In terms of durability, I've never tested them side by side. Appearance wise both finish down great.
09-02-2017, 09:57 AM
#113
986DTM
Yes I have it on my shelf and I agree with basically everything you have said. It seems it can be worked Forever. I tested it against speed and 4 other AIOs a few months back, the thread on that is here on AG but it lacked any real protection abilities. I think it was gone within the first month. While it is nice to work for a long time that was also the down fall as it was I guess oily during wipe off so took more effort, not a huge issue but more of an annoyance when trying to turn and burn a job. I have it as on some paint like the Escalade I did a few weeks back mez gave me the best overall job compared to speed, 151 and megs 66
01-07-2018, 04:15 PM
#114
986DTM
I think Menzerna 3n1 is great to have because like you mention it virtually never dries up so it can be a blessing on paints with alot of oxidation being removed because even removing heavy amounts of oxidation doesn't seem to have any impact on Menzerna 3n1. I agree that Speed is the best option for polishing vehicles in the sun and is much easier to use on cars that just need a light cleaning and gloss enhancement.
01-09-2018, 07:52 AM
#115
I like the user experience of Speed over 166. Mostly because D166 smells so bad. Speed was a lot thinner, spread out well, and wiped off easy.
If given the choice, I'd still use DG501 over either of them.
01-09-2018, 09:39 AM
#116
Ok first of all I honestly only read the first three pages of comments. With that said I had the chance to use both Speed and D166 recently on some great muscle cars headed to Mecum in Fl. recently. Started on a 64 vette fastback with a year old repaint that was extremely soft. First was D166. With a Megs mf polishing pad it hazed the black paint. Switched to a Yellow Megs thin foam. No hazing but not enough correction. Switched to HD Speed and mf polishing pad. bingo , looked great. My guess there is a small amount of filling going on but I'm only guessing and there was no time for a panel strip to check. Next was a old faded lacquer painted 63 split window vette. Neither AIO would cut it and switched to M300 and mf cutting pad. Finished with Speed and yellow Megs pad. Looked great. 65 vette convert was next. D166 and mf polishing pad and it looked fantastic. Did a total of six cars ( 56 and 57 T-birds and four vettes ) in two days. 14hrs first day and 12 the second. IMO both products will stay in my arsenal for this type of work. With a assortment of pad types and these two products my job was made a lot easier then just sticking to a single product.
01-09-2018, 10:02 AM
#117
I've not yet tried Speed, but I've been using 166 for a few weeks now and I LOVE it. It is extremely easy to work with and wipes off effortlessly. I don't have any issues with the smell as I actually like the smell of it.
01-09-2018, 10:08 PM
#118
I've always used (and loved) mirror glaze #6.....just received my first bottle of speed and going to give it a try. Sounds like this new meguiars product is great too, but I find that most of their products are top notch. Excited to try the speed after the great reviews.
Sent from my SM-G935V using Tapatalk
01-09-2018, 10:43 PM
#119
Cleankat
Ha! Funny you mention #6, I just did a car with that this morning.
01-10-2018, 12:16 AM
#120
M300??? or did you mean d 300?
Tom
Mr Tommy's
Wash, Buff, Wax
Website: mrtommyshine.com
