We wanted to provide more specific information in regards to the cutting ability of D166 Ultra Polishing Wax. What is unique about this product is how well it responds & performs to a wide array of application methods, like the user's choice of machine, pad/disc, and technique.
To reiterate, Meguiar's approves & recommends the use of foam & microfiber
cutting pads/discs for this new AIO, D166 Ultra Polishing Wax
when more aggressive cut is needed or desired.
We anticipate a popular application method will be dual action polisher. We are excited to tell you that when used on a dual action polisher machine like our MT300, with the appropriate cutting pad, either foam or microfiber, and using certain technique like moderate pressure, moderate - slow arm speed, a user can achieve defect removal similar to some
compounds.
Below are examples of Meguiar's Pads & Discs we approve of & recommend for D166 Ultra Polishing Wax based on defect removal & overall goal desired.
This product can be applied with our foam cutting & microfiber cutting discs for moderate to
heavy defect removal:
Meguiar's DFC5 Soft Buff 5" DA Foam Cutting Disc
Meguiar's DFC6 Soft Buff 6"DA Foam Cutting Disc
Meguiar's G3507 4" DA Power System Compound Power Pads
Meguiar's DMC3 3" DA Microfiber Cutting Disc
Meguiar's DMC5 5" DA Microfiber Cutting Disc
Meguiar's DMC6 6"DA Microfiber Cutting Disc
Meguiar's WRFC7 Soft Buff 7" Rotary Foam Cutting Pad
This product can be applied with our foam polishing & microfiber finishing discs for moderate defect removal:
Meguiar's DFP5 Soft Buff 5" DA Foam Polishing Disc
Meguiar's DFP6 Soft Buff 6" DA Foam Polishing Disc
Meguiar's G3508 4" DA Power System Polishing Power Pads
Meguiar's DMF3 3" DA Microfiber Finishing Disc
Meguiar's DMF5 5" DA Microfiber Finishing Disc
Meguiar's DMF6 6" DA Microfiber Finishing Disc
Meguiar's WRFP7 Soft Buff 7" Rotary Foam Polishing Pad
And all of our Foam Finishing Discs & Pads, for light defect removal:
Meguiar's DFF5 Soft Buff 5" DA Foam Finishing Disc
Meguiar's DFF6 Soft Buff 6" DA Foam Finishing Disc
Meguiar's G3509 DA Power System Waxing Power Pads
Meguiar's WRFF7 Soft Buff 7" Rotary Foam Finishing Pad
Don't forget hand application:
Meguiar's W0004 Soft Foam Applicator Pad 4 Pack
Meguiar's X3080 Even Coat Microfiber Applicator Pad 2 Pack
Nick Winn
Product & Training Specialist | Meguiar's Online Forum Administrator
Meguiar's Inc.
Irvine, CA
nawinn@meguiars.com
800-854-8073 ext 3845
