Results 1 to 3 of 3
    Super Member KS_Detailing's Avatar
    Aug 2013
    New York
    649
    Power cord replacement on a metro master blaster
    I need to replace the power cord on a metro master blaster. I have a new cord, was looking to see if anyone has done this before. Looking for a DIY, input, videos? Thanks in advance
    www.ksdetailing.com
    Connect with us on Facebook & Instagram @ksdetailing
    Super Member PaulMys's Avatar
    Jan 2014
    Eastern L.I. NY
    10,773
    Re: Power cord replacement on a metro master blaster
    Easiest way is to remove the cover that houses the trigger/wire connections.
    Note the way each of the 3 wires is routed, and to which terminal. Make a diagram if it helps you.
    Loosen the 3 connections. and remove the old cord. Note each wires length. They will usually be different lengths.
    Cut each wire to the same length, and strip off the same amount of insulation as the old wires.
    Re-route the new cord and wires (check the diagram you made if needed) the same way as the old one, and re-connect each wire to the proper terminal.
    Super Member jshaf's Avatar
    May 2010
    Masontown, WV
    208
    need to do this as well. just noticed the original cord has broken, knew the day I took delivery of it that the cord would not last long, surprised it lasted 5 years. thing kinks like crazy. the only thing I dislike about the product.
  1. Metro Master Blaster
    By Dadillac in forum Auto Detailing Tools and Accessories
    Last Post: 05-27-2013, 08:59 AM
  2. Metro Master Blaster...
    By Lexi65 in forum Auto Detailing 101
    Last Post: 03-22-2013, 08:11 AM
  3. Review: Metro Master Blaster
    By CEE DOG in forum Product Reviews
    Last Post: 03-27-2012, 08:10 AM
  4. Metro Master Blaster Nozzle Help
    By A-train in forum Auto Detailing Tools and Accessories
    Last Post: 03-11-2012, 11:44 AM
