Results 1 to 9 of 9
    Jul 2017
    RI
    531
    rupes pads on non-rupes polisher?
    Like the title says...
    I have been looking at the rupes system and really like the simplicity. I realize I could get a similar result from using the Megs soft-buff pads and any myriad of the existing products out there (currently have 6.5" LC CCS and some 5" LC flats, as well as a couple megs and B&S fiber pads until I decide what I like more) but the simplicity of the rupes system is appealing.
    I have an MT300, but I can't imagine the rupes 15 (in concept) is THAT much different to where you couldn't use the rupes pads on it. Anyone done it before?
    Nov 2009
    Pasadena, CA
    12,615
    Re: rupes pads on non-rupes polisher?
    You absolutely can.
    '03 Corvette Z06
    Super Member dlc95's Avatar
    May 2013
    Rochester Hills, Mi
    6,016
    I used to run Rupes microfiber on my Porter Cable quite often.
    I like RUPES 6" pads on tools like the Griot's Garage 6" DA
    The blue rotates well on the Porter Cable because it's light and airy, the green and yellow start out good but as they become wet you get more pad stall on the PC, not a problem with the Griot's.
    I show the RUPES 7" blue on the RUPES and FLEX 3401 for marine gel-coat finishing.
    Jul 2017
    RI
    531
    Thanks Mike. That being the case I'm assuming the mt300 is at least equal to the gg6 if not more powerful?
    dont know yet really what benefit id see over LC flat pads or B&S pads but good to know it's an option.
    Nov 2009
    Pasadena, CA
    12,615
    Quote Originally Posted by jcat9 View Post
    Actually, I think the MT300 is less powerful than the Griot's.
    '03 Corvette Z06
    Jul 2017
    RI
    531
    Shoot I think you're right. 500w on the megs vs 850. Wish I would have known that before I bought the mt300 though I prefer the 'long tail' of the megs.
    Joe Catanzaro
    JCDetails (RI Based Mobile Detailer)
    http://jcdetails.com
    Nov 2009
    Pasadena, CA
    12,615
    Wattage isn't always an indicator, as the harbor freight DA has more pad spinning torque than the Griot's, and it only has a 600 watt motor. However, the HF isn't as smooth as the Griot's and it's a lot louder.
    I've used both the MT300 and the Griot's and the Griot's felt more powerful.
    '03 Corvette Z06
    Super Member The Guz's Avatar
    Jun 2013
    LA, CA
    8,719
    I have tried Rupes pads on my MT300 and they worked fine. It has plenty of power and torque to spin them and correct the paint. No need to worry about that.
    I rarely use my MT300 these days but the thin Meguiar's foam pads for me are still a better option for the MT300.
  1. Replies: 24
    Last Post: 01-03-2020, 11:12 AM
  2. Rupes polisher, Rupes pads, non Rupes polish
    By joleyred in forum Auto Detailing 101
    Last Post: 05-27-2018, 10:18 PM
  3. Questions on Rupes polisher pads
    By nickbosco in forum Auto Detailing 101
    Last Post: 07-16-2017, 02:31 AM
  4. How do I prime a Rupes Foam Pad on a Rupes Polisher?
    Last Post: 01-10-2017, 11:26 AM
  5. Rupes bigfoot 100mm foam pads on Rupes LH18ENS rotary
    By rah28 in forum RUPES BigFoot Oribital Polishers
    Last Post: 01-04-2016, 07:17 AM
