Re: Audi A5
I just did a 2015 dark blue A6. Guy was on a budget so we kept it simple. Looked like it was only washed with an SOS pad its entire life. Wanted paint shinedd up and wheels to be easier to clean.
Wheels: wash, iron x, then hydro2 lite.
Paint:
Wash - CG citrus wash n gloss high concentrate.
Clay - Grioits syn clay
AIO - HD Speed.
GG6 with white ccs for most panels. Front end used MF cutting pad.
Topped with Merlin's magic potion
Test spot was critical. Told me the speed of arm/ machine to use. Speed 6 med pressure slow arm 2 passes then 2 quick light passes on 3. Let set 30 min before wipe.
2017 BMW M2 - 2017 Ram Laramie - 2016 Subaru Outback - 2015 Ram Outdoorsman
2006 VW Jetta TDI - 2003 Duramax Diesel - 1999 Jeep Cherokee
Re: Audi A5
Paint:
AIO - HD Speed.
I was thinking about ordering some MF pads. Probably should just have some on-hand.
Re: Audi A5
I was a bit nervous that MF would be a bit much but when the orange ccs wasn't doing it I gave it a go. It finished out great.
Note... above I put white ccs when I shoulda said orange. White was too light.
For the HD Speed..... No prime on foam just 4 dots them 2 thereafter. MF I did a very light prime.
All pads 5.5"
Re: Audi A5
Any time I ever needed to compound any scratches out in mine I alway used microfiber. Foam doesn't cut well on VW/Audi and especially BMW. But if you are not trying to get all the defects out then I guess microfiber doesn't matter.
Re: Audi A5
Want to get the best I can with an AIO....any preferences on MF pads? I've never used MF...
Sent from my iPad using AGOnline
Re: Audi A5
I've had great results with HD Speed combined with Uro Fiber MF pads. Don't plenty of black German vehicles and Japanese as well...all turned out excellent!
Re: Audi A5
Black Audis can be super soft, we have a member here who mentions his black Audi paint is soft enough that he can marr it if he doesn't wipe right. So don't be surprised if you get some marring with a MF cutting pad. I would suggest doing a test spot with a MF finishing pad and a MF cutting pad, and comparing the two.
2016 Mazda 3 Sports GT
2015 Lexus IS250 F Sport
Re: Audi A5
Likely you will need the orange pads with an
AIO. My wife and I have A4's and the first AIO was McKees 37 360 and the white pad was not enough. The first session required orange and the maintenance sessions I use white pads. Mine is dark blue and wife's is white.
ScottH
Re: Audi A5
On the whole I'd say Audi's are generally harder paint, however I have definitely had a few with soft paint, so as always, instead of going into the detail with a preconceived plan of attack, rather conduct a few test spots to see how that specific paint is reacting to your various combinations, and go from there.
By dragan75 in forum Show N' Shine
Last Post: 03-14-2021, 07:41 AM
Last Post: 07-22-2018, 12:44 PM
By mjlinane in forum Show N' Shine
Last Post: 02-15-2016, 01:18 PM
Last Post: 09-10-2013, 06:56 PM
Last Post: 05-28-2013, 01:57 PM
