Page 2 of 5 FirstFirst 12345 LastLast
Results 11 to 20 of 50
    Sep 2014
    524
    Re: Gyeon Water Spot Remover - Mistake or Warning?
    From The Gyeon website:
    "While use of GYEON WaterSpot can affect the hydrophobic properties of the coating, so a coating of GYEON Boost or GYEON WetCoat may be in order. Avoid leaving GYEON WaterSpot on paint or glass for prolonged periods of time."
    Super Member kevincwelch's Avatar
    May 2013
    Oak Park, IL (Chicagoland)
    2,686
    Quote Originally Posted by glfnaz View Post
    If anything, I may have left it on too long - and by that I mean it's possible that I didn't wipe it fully away. The thing is, however, I've used it for spot removal before and never noticed anything as bad as this.
    (Sent via my mobile device...)
    Perfection is attained by slow degrees; it requires the hand of time. (Voltaire)
    2013 TESLA MODEL S | Gyeon Syncro | Gyeon Cancoat
  3. #13
    Sep 2014
    524
    I think my making that statement though, Gyeon is aware that WaterSpot hurts the coating. I feel for you and your car though.
  4. #14
    May 2013
    2,686
    Right. I've hesitated to use water spot removers in the past, and this is a good lesson for me. Damn.
    Oh well...
    New purchases!
  5. #15
    Feb 2012
    Palatine Illinois, USA
    24,545
    Quote Originally Posted by kevincwelch View Post
    Oh well...
    New purchases!
    YesGyeon Water Spot Remover - Mistake or Warning? Gyeon Water Spot Remover - Mistake or Warning?
    2022 Elantra N Cyber Gray
  6. #16
    Super Member rlmccarty2000's Avatar
    Dec 2013
    Fitzgerald, GA
    2,002
    Give it a spray of Quartz Max for protection while you are getting ready to recoat.
  7. #17
    Super Member WillSports3's Avatar
    Jun 2016
    Toronto, ON
    1,453
    I avoid waterspot removers for that very reason, it's not that the products took your coating off. It's that they've ruined the surface tension. I would do a test of washing your car and then rubbing a finger tip to feel any differences between the non beading panels and the other panels. My suggestion, if you want to bring back the beading, is to use a super light clay if it needs it, and then instead of a spray paint cleanser, use a paint cleansing lotion of some sort. Then just re coat it. You'll just be adding on another layer of coating with proper surface tension ontop of your old coating.
    2016 Mazda 3 Sports GT
    2015 Lexus IS250 F Sport
  8. #18
    May 2013
    2,686
    I put on a layer of PA High Gloss, rlmccarty2000. That should hold it for while.
    WillSports3, I agree with you. It's just hard to imagine that Mohs was taken down by this product, so I guess the surface tension is modified now. I have done the claying already (Nanoskin), and in a week or two I will hit the hood with a few passes of Jescar finishing polish using a white pad with my Rupes. The hood needs no (or only minimal) correction, so it should be fast. It's a good opportunity to test a new coating.
  9. #19
    Super Member C5Longhorn's Avatar
    Jun 2015
    379
    So what coating are you going to try?
    Sent from my Nexus 6P using Tapatalk
  10. #20
    May 2013
    2,686
    PM sent...
  1. Replies: 18
    Last Post: 03-08-2015, 10:57 AM
  2. Water spot remover
    By Paulyfe12 in forum Auto Detailing 101
    Last Post: 05-26-2014, 12:33 AM
  3. Water Spot Remover, Clay bar, still have stubborn water spots...
    By nissenc1337 in forum Auto Detailing 101
    Last Post: 03-18-2013, 03:32 PM
