Re: Got rid of my Overpriced Karcher PW and bought a Cheap Ryobi & Upgraded it... way better setup!!
Originally Posted by fightnews
The problem is the Karcher pressure washer. They use their own fittings so no other hoses fit the unit.
You can check with Karcher to know what fitting they use. It's very likelly they use the M22 15mm ones. Looks like most electric pressure washers use that size. There are adaptors available to convert M22 15mm to M22 14mm which is more standard.
You could probably have adaptors to other standards as well, you just need to know what your unit has and what the hose or gun you want to use has.
Although using a larger diameter hose will result in pressure loss, so that is not a good idea.
Same problem with the SunJoe PW--they use a M22-15mm connection and the standard is M22-14. But an inexpensive conversion fitting is available on eBay but I can't find the link just now.
the M22/15 is the European standard. Yea, eBay or MTM or some Googling will find the parts you need to adapt. I have the SJ3001 also and fully converted it over
to American standard & quick release too.
I just ordered the hose and couplings hopefully it works
Calnedyr - just reading your questions about the Simoniz brand pressure washer. I also own a Simoniz electric and a Yamaha gas power. I bought a new 50' single wire hose which are more flexible then the double wire as well as a new gun and wand. For the simoniz I had to buy a M22-3/8" for the pressure hose outlet on the machine and a M22-1/4" quick connect so I can use their foam cannon with my new gun. Hope this helps. If you want pictures let me know.
Originally Posted by Hammer77
That's a bummer man!
Alright. I tried a second time. Replaced w a Ryobi 1.2 gpm 1700 psi unit. It’s a little bigger than the one I had but at least it hasn’t blown up on me yet.
First off,I love my mosmatic gun w swivel. Looks good,doesn’t get tangled, and looks like a quality piece.
Second, the pressure washer and factory gun/wand work well for pressure washing my patio .
Third, foamability is not living up to my expectations. I have a brand new mtm foam canon and have tried various settings. I also use Chemical Guys Honey Dew soap. Have super weak suds at best. Pretty much equivalent to my foam gun that works w a garden hose.
I’ll keep messing around w this setup to see if I can improve my foam. Otherwise I wasted good money on my mosmatic and mtm foam cannon cause there was no need for them if I don’t get the foam.
2005 Nissan 350z (Polish Angel Viking-Coat)/2020 AMG GLC43 (Polish Angel Viking-Coat and Auto Gliss 2.0)/2012 Honda Odyssey TE (Jescar Power Lock)/2020 AMG C43 (CQuartz UK3.0 and Auto Gliss 2.0)
You are going to need to switch the orifice to 1.1mm in the foamcannon from the original orifice 1.25mm. Then you get a thicker foam with your PW.
+1 I was just about to write the same thing. the MTM comes w/ an orifice designed for higher pressure gas powered washers.
Unfortunately, the only place to get them is MTM and the shipping is 3x the cost of the orifice.
05-03-2018, 09:09 AM
#100
That's not entirely true. They are available elsewhere if you know where to look.
By carguy2007 in forum Griot’s Garage Polishers - BOSS - 6" DA - 3" DA
Last Post: 11-22-2017, 05:41 PM
By sasson in forum Ask your detailing questions!
Last Post: 04-08-2013, 11:51 AM
By touring in forum How to make money detailing cars
Last Post: 09-22-2011, 01:16 AM
By jlb85 in forum Show N' Shine
Last Post: 08-04-2009, 07:38 AM
