Re: Anyone else order a Makita PO5000C?
Anybody know if you can switch the BPs out between a 5000 and 6000? In the UK we're getting the 6000, but I think a 5" BP would work better for my needs.
I think the only difference besides voltage is the backing plate so I'd expect you to be able to switch. That said, I put a 5" Rupes backing plate on mine because the scalloped edge of the original backing plate makes it look like the pad is spinning the opposite direction from what it is and that annoyed me no end.
Robert
Haha, is there any reason for that scalloped backing plate? Or is it just to make the polisher look different from competitors' products?
As long as the weighting would still be OK with different backing plates, that's fine with me.
Originally Posted by Mike@ShineStruck
Another reason it lacks rotation in free mode besides small throw...the fricking BP is 110 grams..120 if you count the hardware
It isn't an opinion if it's fact. !
I bolted the 3in HD griot BP and will see how it does in free spin mode
So far I only blipped the throttle a few times on speed one in forced mode in air
Mike,
How did the griot's backing plate work?
What causes a pad mounted on a bearing to spin? And, how much energy can be transferred to the paint through a bearing?
Thank you,
Robert
You can, it'll work with no issues as the only difference between the two are backing plate diameter and voltage, 110v vs ,220v
THE ISSUE currently is they don't sell spare plates nor brushes it seems..
I hear PO5000C is USA built whereas the PO6000C is built in Japan..so I can see better quality with the 220v machine...atleast in quality control.
You can also bolt on Griot boss backing plates along with Rupes ES/legacy plates
Dont have a 5,inch to compare but my G21 plate weighs in at 125grams (add 10 grams for hardware)
110grams for the 5inch PO5000C (add 10 grams for hardware)
Griot HD 3 inch is 90 grams
Rupes mini was like 25 grams(Add 10 grams for hardware)
75e plate will need center hole enlarged to fit Makita backing plate Allen bolt
Makita PO5000C bolts up their Backingplate like every other long throw type polisher
Stud type backingplates will bolt up..just need a spanner wrench
Closes to weight with what I've had in hand is the 3in HD Griot plate
Need to weight stock Makita plate with a thin pro vs 3in HD Griot with a LC HDO and see how much closer I get to factory spec weight
Originally Posted by RSW
Mike,
Thank you,
Robert
I'll test this soon with the 3 inch..see if it makes free spin usuable..maybe I'll also buy a spare 75e plate to modify to see if lack of mass helps.
There's no reason I can be sure of. The scallops might let the backing plate sink into the pad and hold it more securely but since I've never had a problem with pads coming off of backing plates that didn't have scallops it seem like a funny thing to have thought about while other issues slid by.
No one should think, just because I use this machine and even advocate for it, that I think it's perfect.
Robert
The only reasoning I can see of the notching was to aid in pad removal from BP
Could be. I like it, if that is so. Keeps from pulling foam off the backing.
Kirk Harrod's Mobile Detailing, Frankfort, KY
Official Detailer of Camarofest 8 & 9
No one has detailed more Camaros.
Originally Posted by VISITOR
if it's true, i'm holding off for a few more months for the Flex 12mm DA if it comes out...
Sent from my iPad using Autogeekonline mobile app
By ScottH in forum Auto Detailing Tools and Accessories
Last Post: 05-12-2019, 07:49 PM
By Heisenberg in forum Product Reviews
Last Post: 11-27-2018, 09:40 AM
By tucko in forum Auto Detailing 101
Last Post: 06-21-2018, 09:18 PM
By DETAILROOKIE in forum Auto Detailing 101
Last Post: 12-26-2017, 08:26 PM
By VISITOR in forum Auto Detailing Tools and Accessories
Last Post: 02-26-2017, 01:07 PM
