Page 4 of 26 FirstFirst 1234567891011121314 ... LastLast
Results 31 to 40 of 259
  1. #31
    Aug 2010
    New Jersey
    15,170
    Re: Flex 3401 vs. Rupes Mille/Makita P5000C, for those that are wondering.
    Ah RSW...I figured out who you are...Mr. Wizard! Good of you to stop by, you've got a lot of insight to offer.
  2. #32
    Nov 2009
    Pasadena, CA
    12,615
    The Mille has higher OPM but less RPM than the Makita. How does this translate for correction between the two?
    Agreed.
    '03 Corvette Z06
  3. #33
    May 2017
    Orange County, CA
    116
    Agreed.
    Both these machines should correct faster than random orbitals. They'll also have the advantage of being able to correct closer to inside edges and along the pillars and next to moldings and gaskets.
    That said, in my experience, OPMs aren't that important on forced rotation machines. As long as there are enough to cross cut the spin, swirl marks won't be a problem. Higher RPMS should equate to a faster machine. Either machine will be a serious addition to anyone's tool set and should make anyone who doesn't have one a more effective detailer.
    If you noticed what Mike said about doing correction on his demo car - that he'd usually use a rotary and follow with a machine to remove the swirls, that's been how I do it ever since I started using a rotary. These machines will make more of the first corrections with a rotary less necessary because they'll have a greater range.
    More RPMS, more movement between the pad and the paint, is better IHMO but either machine for the win.
    RSW
  4. #34
    Nov 2009
    Pasadena, CA
    12,615
    Quote Originally Posted by RSW View Post
    RSW
    You are a wizard!!
    '03 Corvette Z06
  5. #35
    Super Member Dan Tran's Avatar
    Sep 2015
    Portsmouth, NH
    1,055
    I'm such a sucker for new tools.
  6. #36
    Feb 2015
    Ft. Lauderdale,Fl
    615
    Quote Originally Posted by Dan@TheBuffingMoose View Post
    Yes! Me Too! Even though I don't need them.
  7. #37
    Super Member cleanmycorolla's Avatar
    Apr 2012
    Pasadena, CA
    3,805
    I'm like 99% there in purchasing the Makita. But i can also get a slamming deal on a 21mm Griots. So tough....
    Back to the full-time grind.
  8. #38
    Oct 2015
    411
    The new Makita looks amazing. I had planned on getting a Boss 21...
  9. #39
    Apr 2015
    PGH, PA
    1,482
    Quote Originally Posted by craigdt View Post
    Get them both ;-)
    I haven't did any comparisons between my PO5000c, 3401 or G21 yet...but so far found out PO5000c on speed 5 just jiggles and doesn't rotate...but speed 3-4 it has great rotation.
    In forced mode it works great
    .still not sure I like it better then my G21 but def love it compared to my 3401
  10. #40
    Super Member VISITOR's Avatar
    May 2007
    9,729
    Quote Originally Posted by nothingface5384 View Post
    Get them both ;-)
    judging by the video by makita it looked as though as it was doing just that, thanks for the honest feedback thus far...
  1. Replies: 3
    Last Post: 10-25-2019, 05:52 AM
  2. Rupes Mille or Flex 3401
    By Trevine in forum Auto Detailing 101
    Last Post: 03-15-2019, 04:04 PM
  3. Rupes Mille vs 3401 - UPDATED Thoughts
    By TTQ B4U in forum RUPES BigFoot Oribital Polishers
    Last Post: 10-22-2018, 08:26 PM
  4. Flex XC3401, Rupes Mille, or Makita
    By minirips2 in forum Ask your detailing questions!
    Last Post: 04-16-2018, 09:36 AM
  5. Makita PO5000C vs Rupes Mille vs Flex 3401 specs
    By Mike@ShineStruck in forum Auto Detailing 101
    Last Post: 12-23-2017, 02:47 PM
