Page 2 of 2 FirstFirst 12
Results 11 to 14 of 14
    Super Member DETAILROOKIE's Avatar
    Jan 2016
    1,158
    Re: 3 inch pad question
    Well, ok. But as Joe and I both noted, you SHOULD have been getting better defect removal with a 3" pad setup on a PC, then with a 5.5" pad. Something that you might want to explore as to why that didn't happen in this case because there is going to be some time when you want to do spot defect removal with a small pad.
    Yea I'm not sure what happened, but like you said, I might have used too much product, so I'm going to practice using the smaller set up and see what gives me the best results. This was the first time I used my PC as a 3 inch so I have a lot of practicing ahead of me.
    Thank you for all of your advice!
    Sent from my SAMSUNG-SM-G935A using Autogeekonline mobile app
    Jan 2016
    1,158
    Quote Originally Posted by DETAILROOKIE View Post
    Sorry that wasn't you that said too much product. I will have experiment with quantity of product and technique very soon.
  3. #13
    Jul 2016
    3,328
    Just because both pads were orange doesn't mean they were the same
  4. #14
    Jan 2016
    1,158
    Quote Originally Posted by fightnews View Post
    3 inch pad question-20170523_093323-jpg
    These were the type of pads that I used since my boss pads did not come in until today. Do you have any recommendations for pads? Have you had better luck with a thinner or thicker pad with a 3 inch set up?
  1. Griot's Garage random 6 inch polisher and backplate+Pads question
    By iManu in forum Ask your detailing questions!
    Last Post: 03-04-2019, 03:15 AM
  2. 3 inch and 4 inch buffing pad options at Autogeek
    By Mike Phillips in forum Wool & Foam Buffing Pads
    Last Post: 12-14-2015, 07:45 PM
  3. Flex Precision Pads 1 inch 2 inch 3 inch - IN STOCK
    Last Post: 10-28-2015, 08:56 PM
  4. Replies: 19
    Last Post: 02-16-2014, 11:49 AM
  5. 5 1/2 inch and 6 inch Buffing Pads - Pictures and Links
    By Mike Phillips in forum Porter Cable 7424XP Dual Action Orbital Polisher
    Last Post: 11-23-2011, 12:37 AM
