Klasse Twins
When using Klasse AIO do you have to wait to apply klasse sealant or just put it right on top?. Also is klasse sealant really tough as nails?. It is described as protecting your finish for a full year from every hazard imaginable. UV rays/road salt/bird droppings as well as protecting against minor scratching.
Re: Klasse Twins
According to Mike P and others, no you do not have to wait.
https://www.autogeekonline.net/forum...tml#post658225
Wait 12-24 hrs between additional coats of the sealant. Some recommend three coats for the best look.
There's some good tips somewhere around here but I couldn't find the original thread.
____________
Re: Klasse Twins
Here it is from another thread.
https://www.autogeekonline.net/forum...treply&t=76738
Originally Posted by Klasse Act
Congrats on the purchase of Klasse SG, or KSG as I like to refer to it as. Here's a simple way to properly use KSG for best results for application and removal:
-get yourself a bowl and add some water in it.
-I prefer a square cotton applicator, foam seems to not slide across the paint as well.
-find a small spray bottle, like 4 oz or so.
-dunk the applicator into the bowl of water, then pour some KSG into your small spray bottle.
-wring out the cotton applicator, making sure its damp but NOT dripping wet.
-depending upon the size of the panel and/or section your working on 1-2 sprays is more than enough. Wipe the KSG in from left to right, up and down, work it in real good.
-WIPE OFF RIGHT AWAY! This product is acylic, NO need for it to set up, anyone who says you leave it on the car does NOT know how to use it.
-Keep the applicator damp, it makes spreading KSG alot easier, easier is key when using KSG.
-DO NOT USE ON GLASS, its VERY hard to remove for some reason.
-Once your done the car will look great but the key is a 2nd coat, that needs to be applied 12 hrs later as KSG is acrylic it needs time to cure, 12 hrs is the shortest amount of time, the 2nd coat really makes the paint pop
To help maintain inbetween coats of KSG I like to make up a gallon of quick detailer using rinseless wash, adding 2 oz's of KSG into a made up gallon. This not only makes clean ups easier but you also end up adding another layer of KSG, albeit a thin layer for sure.
____________
Re: Klasse Twins
Yes 👍👍
2022 Elantra N Cyber Gray
Re: Klasse Twins
Tough as nails? It is certainly not a coating like CQuartz.
Re: Klasse Twins
What Klasse Act said! I used KSG letting it dry, etc; brutal to remove. Now I use Klasse Act method, sweet!
By Lexi65 in forum Auto Detailing 101
Last Post: 05-16-2014, 07:45 AM
Last Post: 12-15-2013, 03:23 PM
By Bicycle in forum Auto Detailing 101
Last Post: 09-09-2013, 12:49 PM
By John Moore in forum Show N' Shine
Last Post: 06-12-2013, 05:32 PM
By AaronO in forum Auto Detailing 101
Last Post: 05-29-2008, 05:25 PM
