Re: Underwhelming foam out of foam lance
Originally Posted by CopperMtnGuy
Hi everyone! I just got some CG Citrus Wash and Gloss and used it with my foam lance...it was very underwhelming, very watery, not foamy at all. I've gotten wayyyy better results from using "lesser" soaps. I know the CG soap should be excellent and I'm not blaming it, it has to be a user error. I used 20ML of it in the 32oz lance bottle and filled with warm water. I had my lance set for maximum soap output (as in, had the knob turned so the minimum amount of water was added, I tried it a few different ways and this was the best). My pressure washer is an older Karcher 360. Any ideas on what went awry?
20 ml? That barley a 1/2 oz. I use like 6 ounces, you're being far to cheap with your soap
Did about 5oz, and while lots better, it wasn't the thickest I've ever seen come out of my lance. Nothing like any of the pics here. Is there anything that can go bad inside the lance? I took it apart and put new plumber's tape on all the threads. I think my pressure washer is ok too, seems to have the normal power it's always had. Keep adding soap?
17 Land Rover Discovery: Fuji White; 07 Land Rover LR3 SEV8 4WD: Java Black Micatallic; 18 Jeep Wrangler JLU Sahara: Black; 05 Jeep Liberty Limited 4WD: Light Khaki Metallic
Which Lance do you have? If it worked fine before, test again with a soap you know produced lots of foam.
Do you have an electric or gas pressure washer and how many Psi and Gpm?
you may need to replace or clean the strainer as they get clogged...
Foam Cannon HP Pressed Strainer 3-Pack, foam cannon replacement parts
It's some Chinese ebay special lance. The pressure washer is a Karcher 360, 1.6 GPM 1400 PSI.
With 5 ounces of soap you should be getting thick foam. I use an AR Blue 390ss (2000 psi) and a foam lance also from AR Blue and with 3-4 ounces of Reset I get a nice thick clingy foam. The inside of your lance may be clogged up and need cleaning.
This is why foaming isn't economical. It uses way too much soap.
But, if you want shaving cream on your car, this is what you need to do. I have Gtechniq foaming soap in my basket, so I'll see if it foams with lower concentrations.
Perfection is attained by slow degrees; it requires the hand of time. (Voltaire)
2013 TESLA MODEL S | Gyeon Syncro | Gyeon Cancoat
With that much soap and if you aren't getting good foam I'm betting the metal mesh filter in the nozzle is clogged. Take the foam cannon apart and get it out of the nozzle and soak it in some CLR overnight. After it soaks overnight, rinse it really well and put it back in and the cannon should perform much better. You could also just buy a new filter for less than $10.
I suspect is either a clogged strainer, or, some of the thread tape has come loose and is partially blocking something.
By flugufrelsarinn in forum Auto Detailing 101
Last Post: 05-18-2014, 02:53 PM
By BoostN in forum Auto Detailing 101
Last Post: 10-23-2013, 09:26 PM
By Talvanos in forum Hot topics & Frequently Asked Questions
Last Post: 03-14-2013, 01:57 PM
By Lim3 in forum Off-Topic
Last Post: 02-22-2013, 04:37 PM
By SPIROS ANTONIOU in forum Products Guides
Last Post: 12-21-2010, 02:34 PM
