Results 1 to 7 of 7
    Nov 2011
    How do I remove brake fluid from carpet
    I just got a message from a mechanic friend who I've done lots of work for. He said there is brake fluid on the carpet of a 1967 Corvette he is working on. I have NOT seen the carpet yet. I don't know the carpet color, amount, etc.
    I know that brake fluid is essentially hydraulic oil. What products should I start with? I'm thinking start with an all purpose cleaner and go from there. Has anyone got experience with this?
    I have a steamer, hot water extractor and a carpet brush attachment for my Flex at my disposal.
    Thank you!
    Ted
    Super Member ScottH's Avatar
    Nov 2015
    Northern NJ
    895
    Re: How do I remove brake fluid from carpet
    Ted I've gotten oil out of a carpet with McKees 37 carpet pre treatment. I wrote a review on this site and McKees site. Have a look, and a try - this stuff I swear by.
    ScottH
    Nov 2011
    Quote Originally Posted by ScottH View Post
    ScottH
    I actually have some of that. I'm going over to take a look. If forum worthy, I'll attach some photos.
    Quote Originally Posted by Ted Y View Post
    hot water extractor
    Use the hot water extractor after pre-treating.
    Steamers only clean topical stains.
    An extractor forces liquid INTO and the extracts everything OUT OF a material.
    Super Member WAXOFF's Avatar
    Jun 2012
    Just south of the Burgh
    1,283
    The thing that cuts brake fluid is water. Just use water first with an extractor then use a carpet shampooer after that. The only thing you didn't say if it was Silicone Brake fluid that many Vette owners use. That may be a different story.
    2011 Compass Latitude Bright Silver/ 2017 Nissan Rogue SV AWD Premium Glacier White
    REFLECTIVE IMAGE DETAILING
    Super Member FUNX650's Avatar
    Dec 2010
    Ohio, USA
    21,057
    The brake fluid has probably soaked
    down into the padding, sound deadening
    material, and the floorboard. (Hope none
    has landed on any part of the birdcage.)
    IMO:
    It'd be best to pull everything from
    the floorboard up; clean the carpet
    out of the vehicle.
    Also:
    It's quite difficult to clean the padding
    and the other underlying components.
    They may need to be replaced.
    {Cover all the bases in a mid-year}
    Sep 2013
    297
    In my experience hot, soapy water will help with brake fluid.
  1. Clear bra marred by brake fluid spill - way to fix?
    By white98ls in forum Ask your detailing questions!
    Last Post: 07-18-2019, 05:46 PM
  2. Brake fluid on headlights??
    By Whitewater25 in forum Auto Detailing 101
    Last Post: 06-24-2016, 10:40 PM
  3. Brake fluid stained wheel
    By 2011 Kona Blue in forum Auto Detailing 101
    Last Post: 05-12-2016, 12:30 AM
  4. 911, we have a brake fluid emergency
    By Det_Riot in forum Ask your detailing questions!
    Last Post: 10-23-2013, 04:04 PM
  5. brake fluid as a quick detailer?
    By cannibal in forum Introduce Yourself
    Last Post: 12-27-2008, 02:51 PM
