How do I clean a White Aluminum Cargo Trailer?
I own a white Haulmark Passport Cargo trailer similar to (but larger than) this:
It is 2 - 3 years old and has never been washed or waxed. It has grayish streaks from the roof down, and the finish is starting to look a little chalky. Is there something I should use to wash it with before using an all-in-one / cleaner wax to finish it?
Re: How do I clean a White Aluminum Cargo Trailer?
I would use a good degreaser over the entire trailer. Dry it. Tap off metal. Then go at it with 3D HD Speed and an orange cutting pad
Try using a NanoSkin clay pad before you polish.
Speed should do well on an orange pad. McKees also has an RV line that I used on a white trailer that I cleaned. I couldnt get the black streaks off with anything other than the polish step. I used the McKees one step fyi
I detail trailers and also own one like this. McKee's products. They have everything you need.
Thank you, everyone. Can you recommend a good degreaser? I am a complete neophyte!
Thank you!
Thank you!
I would not use degreaser on those panels.They make a degreaser specially for that and ag deosnt sell it.Its called brownroyal. Optimum degreaser only optimum because its low ph and dilute it really down if you must use a degreaser. using degreaser on those panels is not recommended and could etch the panel.keep it wet and work in small sections.If you have to polish out etching or Presoak damage that material is hard to bring back.Only speaking from experience and worked on several of those.
Thank you. I appreciate the feedback. A degreaser did not make sense to me because there is nothing oily or greasy on the trailer. But, since I am a neophyte, I did not question the advice. I think I'll add some TSP to carwash to wash it. That ought to give me a pretty clean surface with which to proceed.
I can't help but wonder if this new wash by Meguiars would work perfect for OP's situation.
Description says it's "super concentrated active formula not only removes dirt and grime, but also bugs, grease, light stains, and light scuff marks as well"
http://www.autogeek.net/meguiars-car-wash-plus.html
By buckeye24 in forum Ask your detailing questions!
Last Post: 12-01-2017, 12:41 AM
By Ncs0816 in forum How to Articles
Last Post: 11-02-2014, 07:53 AM
By El Flaco Taco in forum Auto Detailing 101
Last Post: 04-27-2014, 08:59 PM
By Triple Shine in forum Auto Detailing 101
Last Post: 07-30-2013, 08:17 AM
By dbbrooks in forum Auto Detailing 101
Last Post: 11-03-2010, 07:07 AM
