Page 1 of 2 12 LastLast
Results 1 to 10 of 13
    Mar 2015
    Scratched the surface of detailing 12 years ago, now I'm back at it.
    Granted my titles says I "scratched" the surface of detailing, perhaps it's best if I'm treated almost as a new comer. I understand how to wash a car properly, inside and out, and all the basic principles of polishing/compounding using a random orbital (had the original PC), then of course protection. Probably not enough for a 100% job, but I would say 90%. I worked with Poor Boy's line for the most part.
    With that said, I know much has changed the past decade in detailing. I am hoping to get some product guidance. Keeping my budget to a minimum as I may not have the time to detail/wash even once a month, I am looking for a full package of the following to be under $300:
    - Polisher (my PC has a failed bearing).
    - Contamination removal (anything more advanced than just a claybar nowadays?)
    - Compound & Polish
    - Sealant
    - Foam cannon for pressure washer
    - Wheel cleaner
    - Pads if the budget allows, I have some old pads left.
    Thanks in advance!
    Super Member dlc95's Avatar
    May 2013
    Rochester Hills, Mi
    6,016
    Re: Scratched the surface of detailing 12 years ago, now I'm back at it.
    I'm using NanoSkin sponges instead of clay bars.
    Polishing systems and tools have evolved. Rupes makes a line of large orbit (your PC has an 8mm orbit. Rupes offers 21, 15, and 12mm options) polishers, pads, and polishes - all proprietary, and designed specifically for paint reconditioning.
    Flex has the 3401 VRG, takes the 8mm of the PC, and adds a gear forced rotation, effectively a hybrid of the PC, and a rotary buffer - yet still safe for paint.
    Meguiar's has introduced their Dual Action Microfiber Correction System, which pairs specific compounds, waxes, and Microfiber pads. The DMC5 cutting pad has it's own cult following, being used with compounds from all around the industry. However, the compound it was designed to work with - D300 is one of the best made! It was designed to effectively remove heavy defects in a production environment. It will turn your PC in to a whole new tool...
    We have thin pads from Meguiar's, and Lake Country in foam, microfiber, wool, denim, and rayon.
    In the mid 2000's, Meguiar's introduced their micro abrasive technology (Super Micro Abrasive Technology, or SMAT), which don't diminish like traditional polishes. Check out Ultimate Compound, Ultimate Polish, M100, and M205.
    There seems to be more sealant usage these days.
    Optimum has introduced semi permanent coatings to the industry (at least I believe they have), which has created a deluge of others in the market.
    Lots of stuff new for sure. Seems like it's grown even more since I started lurking here on 2007, and joining in 2013. It's been an adventure, and a lot of fun.
    Super Member VISITOR's Avatar
    May 2007
    9,729
    Quote Originally Posted by SayNoToPistons View Post
    no sense in picking up a $300+ polisher if you aren't going to use it often, so with that said look into picking up a GG6. it's plenty powerful and with the advancements in technology with new pads and liquids, there isn't really much you can't do with it. it also carries a lifetime warranty and GG customer service is tops and they will take care of you promptly without the run around if a problem should ever occur...
    Griots Garage 6 Inch Random Orbital Polisher FREE BONUS!
    5.5" SUPER THIN FOAM PAD OPTIONS for your Dual Action Polisher
    May 2007
    9,729
    - Compound & Polish
    - Sealant
    mckee's 37 has a wide range of new products that have been well received...
    McKee's 37 Waxes, Compounds, Coatings
    McKee's 37 Fast Compound
    McKee's 37 Fast Polish
    Mckee's 37 High Def Paint Sealant
    May 2007
    9,729
    - Wheel cleaner
    McKee's 37 Foaming Wheel Cleaner Gel
    - Compound & Polish
    - Sealant
    - Wheel cleaner
    Thanks in advance!
    Griot's Garage 6" DA
    Griots Garage 6 Inch Heavy Duty Random Orbital Polisher FREE BONUS!
    Nanoskin Autoscrub Handy Towel
    Compound
    SONAX CutMax Cutting Compound 250 ml.
    Polish
    SONAX EX 04-06 250 ml.
    Sealant
    Sonax Polymer Net Shield, sonax polymer netshield, sonax profiline polymer netshield
    Wheel Cleaner
    SONAX Wheel Cleaner, all wheel cleaner, chrome wheel cleaner, aluminum wheel cleaner, full effect wheel cleaner
    Pads = Griot's Boss Pads
    Griots Garage 5.5 inch BOSS Foam and Microfiber Pads - 6 Pack
    NOTE: The Griot's Garage 6" DA Polisher comes with a 6" backing plate and you run 6.5" pads. In my opinion and experience, 5.5" pads are a better fit for this type of polisher and buffing out modern cars.
    Foam cannon
    Foam Cannon HP, Foam lance, foam wash gun, car wash foamer, pressure washer foam gun, autobrite foam lance, autobrite foam cannon
    Aug 2010
    New Jersey
    15,170
    Ha. As dlc95 laid out for you, not much has changed, but everything has changed.
    The processes are all pretty much the same, just most of the products and equipment have improved. There are ways to get better results, faster.
    Mar 2015
    Thanks for all the suggestions.
    As far as coatings go, how far has the industry gone as far as protection? Once I actually put the time to correct the cars, I would love to have them protected for months before having to redo it. The cars sit outdoors unfortunately.
    When I look at all these new products, it almost seems like I was locked in a time capsule for over a decade.
    Aug 2010
    New Jersey
    15,170
    A coating will definitely get you months, but it's still not a force field protecting your paint.
  10. #10
    Super Member rlmccarty2000's Avatar
    Dec 2013
    Fitzgerald, GA
    2,002
    Poor Boys products are still great! That has not changed.
  1. Come back after 20 years
    By Luriael in forum Auto Detailing Tools and Accessories
    Last Post: 04-12-2020, 08:59 AM
  2. After 2 years of detailing in garage, and 9+ years of detailing.
    By Maestro Sam in forum Auto Detailing 101
    Last Post: 03-13-2017, 08:51 PM
  3. Back after 20+ years
    By Studdabaker in forum Introduce Yourself
    Last Post: 06-09-2015, 09:48 AM
  4. They Were Beasts Back Then ~ Some 39 Years Ago
    By Wyle E Coyote in forum Rotary Buffers
    Last Post: 06-08-2015, 08:52 PM
  5. Phew... what a couple of years. Hope to be back now :)
    By ihaveacamaro in forum Off-Topic
    Last Post: 03-13-2015, 08:41 AM
