Re: Will be working on a brand new 2017 GT350 in the early spring, light paint correction needed, what would you EXPERTS use?
Originally Posted by Klasse Act
These are pics from after I was done polishing. Afterwards we pulled the car outside for a tire/wheel cleaning. I wish I had taken pics but the weather was 45 and dreary. Griots wheel cleaner and a random tire cleaner were used here.
After that we pulled the car back into the garage and we did a N914 WW and I then applied a tire coating. I then packed up and headed home. Ted is applying the Optimum Gloss Coat tonight, garage should be around 68 so it should be good to go.
I know it's going into the dealership for some non-mechanical work and I just hope the car isn't touched anywhere it doesn't need to be.
Thank you but it wasn't hard because the car is so new! Ted previously washed it, chemically decon'd it, then used the Griot's yellow clay mit but after he did the baggie test he grabbed actual clay and got the results he was looking for. He finished by masking everything off but using the Optimum Hyper Polish made that unnecessary!
Looking forward to Ted's complete thread
2022 Elantra N Cyber Gray Some say..."He likes Swedish fish because they're made with caranuba wax"
If you want the best look out of Glosscoat, use a triple coat. It doesn't add more protection but it does make it look just incredible. Hyper polish is great, the spray polish makes priming the pad easier.
How long in between costs?
An hour inbetween is fine. What I like to do is after the car is coated, pull it into the sun to bake for an hour, back into the garage and let the paint cool off a little then do the second coat.
