Me saying that degreaser or apc drys out your hands was a example for using the wrong product for the wrong job.
Me being misleading? I do not know if you read the entire write up or just skimmed through it. I wrote that very statement that pad cleaner is stronger and more affective at cleaning foam than apc or degreaser. The problem is the residue that remains from degreaser/apc/dish soap. That is what is drying out and degrading the pad.
All purpose cleaner and degreaser was not designed and formulated to clean foam. Polishing pad cleaner is. It is stronger more effective and leaves no residue behind, because it was designed for specifically for foam and foam only. If you was to use pad cleaner on leather or other surfaces it can cause damage being that it was only designed for foam
Rasky earlier talked to Jeff Brown griors garage product developer and he said the following " they utilize surfactants rather then relying on sodium-salt based cleaners which can leave behind a residue"
Again not designed formulated tested for foam. Like i said in my write up you will remove the polish out of the pad however residue will remain in the pad.
Something i did not put in my write up and is a perfect example is microfiber cutting pads.
If you use the black boss microfiber cutting pad you will see after using apc/degreaser/dish soap a white residue on the hairs of the microfiber. Because its black. And no matter what after the fact even the polishing pad cleaner does not remove the residue.
If you use microfiber cutting pads you will notice how the microfibers feel hard and dry. That is from the remaining residue.
Again like i said in my write up you can use gasoline and it will remove the polish, that does not mean no damage is being done.
Dish soap was designed for dishes. Car soap was designed for automotive paint. All purpose cleaner and degreaser. Did not go under multiple chemistry tests to see if they are damaging pads. Pad cleaners sole purpose was to clean pads and pads only.
You can use dish soap to clean your car and it will get clean so why do we use car shampoo?
Sent from my SM-N920V using
Autogeekonline mobile app
