Oil field truck
Hey all,
I booked a 2016 pickup truck for Tuesday that has lived in the oil field. The interior is not bad, it had seat covers that I will just toss per the owner, and weather tech floor mats, so really it will not be terrible. The outside though has more than just mud on it. It almost needs a degreaser or something. What should I spray on it that will be paint safe before my clay polish and sealant? Would just Sonax or something like it work, or should I spray an APC?
thanks,
Brad
Re: Oil field truck
Tar X is a good choice as well as iron x. Maybe mix in some apc to your wash soap or ssomething. Another good choice is to hit the car with zep 505 as it's an excellent degreaser and then use apc with car soap in your wash bucket.
Re: Oil field truck
Id try stoners tar minator. Cannot vouch for it with no experience but have heard good things about it. Id personally foam soak with an apc and soap, then spray tarminator. maybe then an iron remover then rinse those two off then clay
Bill 1234
2004 audi a6 quattro (traded).
2015 Ford Escape 2.0l ecoboost 4WD
Oil field truck
I love tarminator it works awesome
Re: Oil field truck
Probably has driling mud and other chemicals used in driling process on it. This is where I put the rinseless down and hook up the pressure washer. A good pre-soak with degreaser will benefit you here big time. Foam gun/cannon pre-soak after as well.
Carolina`s Finest Detailing - Charlotte areas preferred CQuartz Finest Reserve & GTECHNIQ Crystal Serum Ultra coating center. STEK/Suntek PPF
www.Carolinasfinestdetailing.me
Re: Oil field truck
Thank you all. I have no idea what is actually on it and told him no guaranty it will all come off without some permanat damage to the paint but I will give it my best. He is fine with that.
The only thing I don't have listed above is tarminator, is it available locally at all? I do have a gallon of bug squash also, I wonder if that may break down some of what's on the truck. Unfortunately I didn't think of taking pictures just quickly looked at it. He said he was going to take it to the spray n wash before I got it so maybe some of it will be off.
Re: Oil field truck
Tar X and Iron X come in a single product called TRIX. According to the CarPro advertising, it is full strength Tar X and Iron X in one product. Might take more than one application, but this might be the best to go with as it should remove iron and/or oil/greasy contaminants in one spray.
Re: Oil field truck
Originally Posted by Coopers ST
Hey all,
thanks,
Brad
I found poor boys bug squash diluted to work great for this situation. Not really a poor boys user but they have a home run on this product.Bought 3 gallons of this week alone.Needed to find a product to use underneath jets and small private air craft.The underside of these planes are covered with oil and it's really thick.Was using paint thinner to remove prior,but bug squash cuts right through it spray and wipe.Great product and super cheap.
Re: Oil field truck
Just don't let it dry on the paint keep it wet all the time.
Re: Oil field truck
I had a lot of road tar from oiling down dirt roads and I filled a garden sprayer with kerosene. I let it sit on the paint for about an hour then washed it off. Repeated once more with the kerosene and then washed and polished as I would normally.
I had previously tried various tar removers and it cost so much in material that I switched to kerosene.
By Redfireshaker06 in forum 2015 Autogeek Detailfest
Last Post: 03-28-2015, 05:10 PM
By audiophile64 in forum Auto Detailing 101
Last Post: 05-09-2014, 07:57 AM
By SuperGlide in forum Auto Detailing 101
Last Post: 12-19-2012, 03:14 PM
By Peejaboo in forum Introduce Yourself
Last Post: 12-06-2012, 11:19 PM
By Flash Gordon in forum Off-Topic
Last Post: 08-08-2010, 12:34 AM
26 | 27 | 28 | 29 | 30 | 31 |
