Re: Constant bonded contaminates on daily driver
Originally Posted by fightnews
what product is that?
Ammo boost
If I can make a suggestion, especially since your vehicle is coated to spray down the sides of your vehicle with half half vinegar and water right before your regular wash and then before you rinse it off tar X and iron X or some kind of fall out remover and let it dwell before you rinse it off. Try that and see what results you get.
Originally Posted by Souldetailer
I would think daily spray-offs would help. Trying to keep the winter elements off the paint may keep those LSP robbing varmits at bay. If there's a product to do this, I don't know of it. Good luck.Darrin
Hard to do when all your outside water is frozen. Unpleasant and impractical.
EDIT: Perhaps you didn't mean water. If you meant chemical that can be done in a garage, then perhaps. For many of us using a hose in winter is not an option.
Originally Posted by HUMP DIESEL
The wash itself may not be removing enough of the road gunk. As the picture shows, you are in snow, which means brine and salt on the road. This can build up really easily on any vehicle. You may need to use something that can break down this road grime. Depending on the coating, it should not be affected by the chemical, if it is fully cured.
Try that and see if you see a different result.
HUMP
like what can you name some products for that?
Could adding N-914 to the wash help perform that function?
Personally I'm thinking about using an aerosol rubber coating on the lower part of my car next winter in order to get my mind of the contamination. Won't be able to do anything about it and it won't mess with the paint.
Only problem is it'll look like crap.
Skickat från min SM-G920F via Tapatalk
By v1ru5879 in forum Auto Detailing 101
Last Post: 08-25-2015, 08:30 PM
By solman in forum Products Guides
Last Post: 07-27-2014, 11:54 AM
By sportscarhiatus in forum Off-Topic
Last Post: 04-17-2012, 12:35 AM
By Matt S. in forum Show N' Shine
Last Post: 02-02-2009, 07:59 AM
By Locc in forum Show N' Shine
Last Post: 08-25-2008, 08:46 PM
