Results 11 to 20 of 35
    Sep 2016
    Las Vegas, NV
    201
    Re: Softest microfiber available?
    GSM and softness are not related. GSM is a measure of density, not softness of the fibers the towel is constructed from.
    Jan 2017
    Quote Originally Posted by Tempest45 View Post
    Thanks, I'm aware GSM is unrelated to softness, which brings me back to my original question, does anyone know what the softest MF available is. From what I can tell a 70/30 mix is the softest I've seen with any of the MF manufacturers.
  3. #13
    Aug 2010
    New Jersey
    15,170
    Quote Originally Posted by Zevulin View Post
    Just like with the GSM issue, I'm not sure that the fiber mix is the be-all, end-all recipe for "softness" (whatever that is, it's not a technical term). Here's a discussion of the fiber blend from a towel website that will remain nameless (ok, it's MFT):
    "By far, the most common questions asked have to do with the blend or composition of the microfiber material. Microfiber is a blend of two man-made fibers, polyester and polyamide. Most commonly 80/20 and 70/30. Experienced users of microfiber products notice that some of their towels are labeled 70/30 and some are labeled 80/20 (sometimes 85/15 or 75/25). Some users notice that they like the towels labeled 70/30 better and assume that they are better because they are 70/30, other users notice that they like the towels labeled 80/20 better and assume that it is because they are 80/20. But this is NOT the case.
    Let me tell you why. First of all, there are many other factors that effect the quality of a microfiber fabric, and there are many factors that effect the the performance for a particular task. There can be huge quality differences between two similarly constructed fabrics (yarn quality, construction quality, quality control), and there can be huge differences in performance (for a particular task) between two quality fabrics (i.e fabrics for wet mopping do not work well for car drying, and fabrics for car drying don't work well for wet mopping). And for the most part none of these quality or performance differences can be accounted for by the stated polyester/polyamide blend of the fabric.
    Second, most microfiber fabrics are labeled incorrectly. The truth is that the U.S. Government requires that companies label their imported products with the country of origin and the content of the product (in our case the ratio of polyester to polyamide). They don't require that these content declarations be 100% accurate. In fact for a given product on a given production run, there will be a +/- 2% difference in fiber content, and no perceivable difference for the user. On top of that, a manufacturer will label the towels in what ever manner (within reason) the buyer requests.
    You may be thinking, "That sure is deceptive.", but it really is just a matter of semantics. For the most part, all microfiber yarns start out as a blend of 70% polyester and 30% polyamide. For most microfiber products (not waffle weave) the microfiber yarn is woven through a polyester backing (ground), at this point the composition of the product is closer to 80% polyester and 20% polyamide, because you have to add in the 100% polyester backing. Some factories will call this fabric 70/30 and some 80/20."
    Then there are some other factors, such as how the fibers are split or woven, etc. I'm presuming you started this thread because you swirled your instrument cluster, since you started a thread about that at the same time. So there are multiple considerations, what cleaning agent was used in conjunction with the cloth, was the dirt/dust on the lens abrasive, was the towel clean, etc.
  4. #14
    May 2007
    668
    As = as important is pre spec purchase details --- the right density, nap given the application, edge detail of towel, etc which is all the easy part of this......proper care and use is probably 90% MORE important than the pre-purchase to maintain such ~softness~.
    I've got plenty of ~premium MF's~, and maybe it's my luck of the draw, but this particular brand --- which see's either water of a very very light interior cleaner, is nowhere as soft as when it was brand new, nor the 50 different ways I've tried cleaning it, etc, will it get back to the softness level I expect from it.
  5. #15
    Super Member DogRescuer's Avatar
    Apr 2013
    Hurt, Va
    1,801
    I believe gsm= grams per square meter.
    Steve
    -The Titanic Was Built By Professionals But The Ark By Amateurs-
    "Boanerges"
  6. #16
    Jan 2017
    Setec Astronomy-Then there are some other factors, such as how the fibers are split or woven, etc. I'm presuming you started this thread because you swirled your instrument cluster, since you started a thread about that at the same time. So there are multiple considerations, what cleaning agent was used in conjunction with the cloth, was the dirt/dust on the lens abrasive, was the towel clean, etc.[/QUOTE]
    Appreciate the info, I actually started the clear plastic thread because I recently replaced the windshield on a motorcycle in my collection and ultimately would like to keep it micro-swirl free. From threads I've read here I guess even the softest MF can cause micro-swirling if used dry. If you had to pick your favorite MF for maximum softness in your opinion which would that be?
  7. #17
    Aug 2010
    New Jersey
    15,170
    Eh, I dunno, I'm the wrong guy to ask about that, if I stuck my head in it that far, that's all I'd be doing all day is worrying about whether my towels were the softest, whether they were staying that way, whether some new towel was softer...wait a minute...that sounds like my life already...
  8. #18
    May 2007
    668
    I would use a low/no.no nap MF for that. Either the TRC Glass and or even something like the Large CQ Suedes which are quite nice. I have had terrible luck with the Boa's
  9. #19
    Nov 2015
    Los Angeles, California
    13,765
    Is 70/30 mix MF the softest available?
    Not sure if they're any softer than 80/20's, but they'll be more absorbent. When looking for a solid drying towel, I make sure to pick out ones that are 70/30.
  10. #20
    Jan 2017
    Quote Originally Posted by chefwong View Post
    I'm I correct then in saying there are no towels than can be rubbed on a dry soft surface without creating swirls?
  1. Best - softest NON-LINTING MF towel?
    By PDC in forum Ask your detailing questions!
    Last Post: 02-14-2020, 04:50 PM
  2. Softest. Paint. EVER!
    By brettka7 in forum Auto Detailing 101
    Last Post: 05-11-2016, 02:57 PM
  3. What is the SOFTEST FOAM/ Wax applicator out there
    By chefwong in forum Auto Detailing 101
    Last Post: 08-11-2011, 05:47 AM
  4. HELP - SL65 Black Series......softest paint ever
    By kakeuter in forum Ask your detailing questions!
    Last Post: 06-06-2011, 11:46 AM
  5. Softest Microfiber Cloth?
    By kovalchuk71 in forum Product Reviews
    Last Post: 11-21-2009, 08:41 PM
